Author Topic: DT1 Wheels  (Read 4347 times)
Offline 52
DT1 Wheels
« on: August 14, 2009, 04:45:27 pm »
does anyone know how to ID DT1 wheels-pre-70 type. I assume RT-1 same. Particully rear.
Re: DT1 Wheels
« Reply #1 on: August 14, 2009, 08:00:07 pm »
They're all the same except the early bikes had 19" front rim, and the RT2MX / DT2MX have the later conical hub.
DT250/360A also have the same wheels.
Offline 52
Re: DT1 Wheels
« Reply #2 on: August 15, 2009, 09:17:25 am »
thanks Nathan, wasn't real sure if that was the case.
Re: DT1 Wheels
« Reply #3 on: August 17, 2009, 08:32:56 pm »
So are the full width pre 70 or can you use pre 75 conical hubs as a carry over
Re: DT1 Wheels
« Reply #4 on: August 17, 2009, 09:52:08 pm »
Interesting question, Freaky.
The conical hubs (322 prefix) weren't seen until the RT2MX of 1972 (I think it was '72 - definitely after 1970).
Logically, this means that they're NOT a legal part for pre-70 - however, I've wondered whether the eligibility allowance for 'All RT1 fitted with non-reed valve' means that you could front up with an RT2MX with an earlier barrel, and be good to go?
I've been running the full-width hub because there's no question about legality, they're cheaper and the brakes are great. And because I'm buggered if I can feel the weight difference.
