Marque Remarks
British (BSA, Greeves, Triumph etc)
BSA B44 barrel sleeve
Topic: BSA B44 barrel sleeve (Read 2477 times)
bazza
August 07, 2009, 05:23:20 pm »
Do the sleeves in the B44 press out with heat? Are they Pinned? Or are they moulded in for good? Mine does not budge but has had a groove from piston pin down it
Once you go black you will never go back - allblacks
Embrace patina
LWC82PE
Superstar
Re: BSA B44 barrel sleeve
August 07, 2009, 05:59:03 pm »
Yes and if they are not pinned expect big trouble. i had to fix one that had the liner moved because the previous repairer didnt pin it.. Made a mess of the barrel.
Marque Remarks
