Author Topic: CT125  (Read 3228 times)
Offline Rosco86
  • Brisbane
CT125
« on: August 06, 2009, 11:55:04 am »
Presently restoring a Junior Speedway solo that uses a CT125 Honda motor. Need a carbie to suit. I would imagine it would be the same size as a SL125 and other 125 Hondas. Does anyone know what size they are? Reasonably important as the rules do not allow for any changes to carby size. Local honda dealer really does not want to deal with it unless he can make a "new" sale from past experiences.Anyone have one lying around?
NQ Rosco.
Offline micks
Re: CT125
« Reply #1 on: August 06, 2009, 09:03:47 pm »
have you tried any bucket sites yet ?in sydney i think there is two teammaddogracing and ozbucket racing the later may note have a forum.good luck
Offline Grasy 6
Re: CT125
« Reply #2 on: August 06, 2009, 10:04:47 pm »
Hi Rosco CT 125 uses 22 mm Kehin, SL 125 use 24 mm Kehin , 1977 XL 125 use 26mm oval type carby. Get rid of the CT head a use an XL head bigger valves std over the CT & SL heads. Easy to recognise XL head has the number 383 is stamped near the head gasket where CT has 384 . If ya can not find one I have a few of them. Used them in Bucket racing Dirt Track. Still got the bikes if any one wants to buy them. From memory your bike is locked in one gear . You can get them going with a bit of work 17 Hp out of mine.Valve train is the limiting factor use RD vavle springs with titanium retainers good for about 14,000rpm with the right cam grind. Are you allowed to use methanol.If you are going to rev it make sure the centrifugal filter on the end of the crank is a good one as they explode through the clutch side cover with a bang & destroys big bend immediatly.Been there done that a few times .
Offline Rosco86
  • Brisbane
Re: CT125
« Reply #3 on: August 08, 2009, 11:14:52 am »
Thanks Grasy
Rules a pretty rigid, no methanol, but I think I can get away with the XL Head and carbie. If you have spare head and carbie you want to sell give me a pm. You certainly have the good oil in this area.
NQ Rosco
Offline Grasy 6
Re: CT125
« Reply #4 on: August 12, 2009, 07:58:42 pm »
Hi Rosco I sent you a pm regarding the xl 125 bits . Cheers Grasy
« Last Edit: August 12, 2009, 08:11:34 pm by grasy »
