Author Topic: Ignition coils  (Read 2965 times)
Ignition coils
« on: August 05, 2009, 08:48:39 pm »
I'm wondering which ignition coils people use when running points still & if only the rear plug gets used, most photos I've seen only appear to run 1 lead but I'd like some opinions as to which is best. Bike is a '73 380 & from memory has a NGK B9HS in the front & B8HS at the rear with old coils fitted, front plug was prone to fouling & killing power so I'd like to replace the coil/s see what effect that has
Re: Ignition coils
« Reply #1 on: August 05, 2009, 09:31:24 pm »
hi
i have a standard 1972/73 twin plug ignition and mine works good.i use 2 coils and 2 short reach ngk b8s.only just rebuilt it but 1 race day under its belt and came through ok no fouled pluds and i use 20:1 oil mix as well.leter models used 1 coil. go to cz madness and get the manual from his web page it tells you how to do evey thing
fellow 380 owner
jim
Offline shortshifter
  • Sunshine Coast QLD
Re: Ignition coils
« Reply #2 on: August 07, 2009, 10:40:54 am »
I'm running a single coil system with ngk 8 plug.works well.Jim what oil are you using in your 20:1 mix?
Re: Ignition coils
« Reply #3 on: August 07, 2009, 02:50:37 pm »
TTS AND 98 CALTEX
