Marque Remarks
Suzuki
RM125 A rear hub
Topic: RM125 A rear hub (Read 2901 times)
ghostrider
C-Grade
RM125 A rear hub
August 04, 2009, 03:05:12 pm »
Can anyone tell me if suzuki changed the rear hub shape from 1976 to 1978 ,my rm125a has a stuffed rear rim and I have found a rm125c rim for sale and wondered if I can use the 78 rim on the A model
DR
Re: RM125 A rear hub
August 04, 2009, 03:30:11 pm »
they did change them ghostrider, the '78 125C is totally different due to the sprocket mounting and floating brake set up. '75-'77 RM125M/S/A/B are the same hubs
is the C rear rim you found complete with backing plate? I be looking for one shortly for my C as it has a B wheel fitted
ghostrider
C-Grade
August 04, 2009, 05:04:13 pm »
I have'nt seen the wheel /hub etc yet Doc ,but when I do , will check it out for you (prob weekend) ,,,thanks for the info .
ghostrider
C-Grade
August 09, 2009, 08:04:17 am »
Doc ,
had a look at the "c" rim ,its actually a wheel set up on a rm125N/T swingarm bolted to a 125C chassis
(checked frame number). So I am guessing that this rim/hub is from a n N/T model, but I will keep looking around for you...
DR
Reply #4 on:
August 09, 2009, 06:10:57 pm »
no worries and thanks Ghostrider was worth asking on the offchance
Marque Remarks
Suzuki
RM125 A rear hub
