Author Topic: Bultaco 21" front wheel  (Read 3989 times)
Offline steve234
« on: July 31, 2009, 10:12:31 am »
Chasing a 21" front wheel for my M106 astro (1971-1972).
Even a hub would do.
Part number 66.04-001
Steve
Bultaco M106 Astro
Wanted: Dirt track bikes / parts / info
Offline steve234
Re: Bultaco 21" front wheel
« Reply #1 on: August 16, 2009, 02:24:41 pm »
anybody?
Bultaco M106 Astro
Offline David Lahey
« Reply #2 on: August 16, 2009, 05:36:02 pm »
Steve that part number doesn't mean anything to me and my limited knowledge of Astros had me thinking that Astros had no front brake. If the hub you want has a brake drum, I do have a few front Bultaco hubs from the late 1960s and 1970s but they are all from bikes with front brakes. If you can show what the hub you want looks like, we may get somewhere.
previous pseudonym feetupfun
Offline steve234
« Reply #3 on: August 16, 2009, 06:00:00 pm »
Feetup the first couple of astro's were pretty much pursang's with different engine mods (square jug not round). So i think a M86 pursang is the same hub for those models until 1974 when they bought out the M145 with a spool hub and a disk at the rear. The M106 was produced around 1971-1972, so mk5/6 pursang hub should do the job. I'll scan the part discription tomorrow which will help identifing what i'm after.
Bultaco M106 Astro
Offline David Lahey
« Reply #4 on: August 16, 2009, 06:59:19 pm »
I've got a Mk5 Pursang hub available
Offline Moto
« Reply #5 on: August 16, 2009, 08:51:56 pm »
Steve,
        Paul has a Bultaco front wheel that he is giving away(General Discussion)but it is pickup only.If the Mk5 hub being offered by feetup is true it would be a steel hub(they only made them for one model, the MK5's)the next year they were exactly the same only made of alloy with a spray on chrome braking surface.The steel hubs worked good but were heavy.
Offline paul
« Reply #6 on: August 16, 2009, 09:06:02 pm »
listen i didnt know it was a bultaco wheel talk to curly and see if he really needs it
Offline steve234
« Reply #7 on: August 18, 2009, 11:03:14 am »
Bultaco M106 Astro
Offline David Lahey
« Reply #8 on: August 18, 2009, 06:43:03 pm »
Here is the (steel) hub from Mk 5 Pursang I was thinking of selling.
http://ozvmx.com/community/index.php?topic=8045.0
I might also have an alloy one like the one in photobucket. I'll have a look tomorrow.
David
Offline David Lahey
« Reply #9 on: August 19, 2009, 06:04:38 pm »
Sorry steve234, no Mk 7 Pursang front hub available. The front hub I was thinking of turned out to be a 140mm hub (Frontera/Alpina)
I did weigh the Mk 5 Pursang steel (125mm) hub and including both bearings and the spacer between them it weighs 1607g
For comparison, the above 140mm Frontera hub weighs 1057g with one bearing and no spacer
David
Offline steve234
« Reply #10 on: August 20, 2009, 08:33:39 am »
Cheers David, i'll keep looking for a hub similar to what i've got for the moment and see what pops up.
Bultaco M106 Astro
