Author Topic: bleaching yz tank  (Read 2924 times)
0 Members and 5 Guests are viewing this topic.
Offline philthy
bleaching yz tank
« on: July 29, 2009, 06:30:41 pm »
Hi all,just spent the weekend sanding my yz250f tank as per the article in VMX.I have finished the sanding with 1200 wet & dry,but not yet polished.Although it has made a big improvement I still have very slight staining on the bottom where the fuel has sat,my question is will bleach help or will it undo all the work I have done thus far,or am I better off polishing with jiff ect.I did take quite a lot of plastic off so didn't want to go much further!
yz125d yz250g yz250f it250j rm125b rm125a
Offline oldyzman
  • 250 two stroke!
Re: bleaching yz tank
« Reply #1 on: July 30, 2009, 09:03:27 pm »
I reckon its probably coloured (stained) through, I have heard of soaking in bleach, Any coments as i have similar prob
Brett
« Reply #2 on: July 30, 2009, 09:06:48 pm »
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #3 on: July 31, 2009, 06:00:39 am »
Unless you were using a belt-sander you should be fine - plastic tanks are usually about 6mm thick!  As to bleaching, a couple of litres mixed with water, drop in your tank and wait a couple of days.
Offline PEZBerq
  • Brisbane
« Reply #4 on: August 01, 2009, 07:34:17 am »
Luke...are you bleaching the inside of the tank or outside...or both?
« Reply #5 on: August 01, 2009, 09:57:49 am »
I tried bleach from the local hardware store, and it was useless.
There's Hydrogen Peroxide and another type, both labelled as 'household bleach'. I can't recall which type I used, but I figure that you need to use the other one.
