Author Topic: Q FOR TS125K FILES  (Read 2189 times)
Q FOR TS125K FILES
« on: July 25, 2009, 06:38:20 pm »
is the maggie coil mounted on the stator for the spark on the top left hand side on a angle?and what would the resistance be for this coil and the h/tension coil?
DR
Re: Q FOR TS125K FILES
« Reply #1 on: July 25, 2009, 06:54:18 pm »
correct primary coil location yes
resistance (between the leads) should be about 1.1 ohms
resistance of the insulation (between the windings and the metal core) should be at least 5 megohms
DR
« Reply #2 on: July 25, 2009, 06:56:03 pm »
late edit..for ignition coil the resistance between the +/- leads should be about 2 ohms but it can be less in some instances
« Reply #3 on: July 25, 2009, 07:13:28 pm »
thanks for that Doc,ive got 2.2 ohms but when playing with a brush cutter spark module and victa coil wjth it plugged into the black/yellow stripe wire even kicking over super fast i got spark some times when i shifted to the tellow/white wire i got a fat clicky/click sounding spark so might shift this coil into the faulty coils position as they seem to have the same bolt spacing as a cheep fix to get it going,i got it off epay for the rm125m pipe new retread back tyre and new chain/spockets for $150 and will use the chassis for dirt track with a rm125s motor as i dont like long travel bikes for sliding on
« Reply #4 on: July 25, 2009, 07:17:45 pm »
and whats the resistance on the h/t coil secondary winding with no plug cap ive got less than 2k ohms?
DR
« Reply #5 on: July 27, 2009, 05:03:56 pm »
resistance for this should be in the range of 5000-11000 ohms going by the good book ;)
