Author Topic: 1983 honda cr125 water in the bottom end mixed with oil  (Read 3397 times)
pimpolligist16
« on: July 25, 2009, 02:00:16 am »
the 83 cr125r is liquid cooled when i  start the bike water is sucked throw the motor to cool it and i whould ride it come back cheack colent level and there will be no water in it i cheack the oil were the clutch is sand it is milkey gray i am running strate 30w oil in it  what can it be ?
090
Re: 1983 honda cr125 water in the bottom end mixed with oil
« Reply #1 on: July 25, 2009, 07:15:21 am »
It is the most common problem with water cooled Hondas. The water pump housing is corroded . You will have to take it off and get it repaired. You have to grind out the corrosion and replace it with Dembicon or similar liquid metal product. They all suffer from it.
pimpolligist16
« Reply #2 on: July 25, 2009, 08:31:31 am »
thers no sings of it beeing corroded can it be the gasket?
Offline Hotelmoto
« Reply #3 on: July 25, 2009, 08:58:42 am »
Or the seals on the water pump shaft
pimpolligist16
« Reply #5 on: July 25, 2009, 01:45:14 pm »
well i orderd a complet gasket kit for it a few days ago  so when it gets in i will put them all on and hopfully that is what it is
090
« Reply #6 on: July 25, 2009, 07:46:21 pm »
I dont believe its not corroded. They all are because the cover is made of magnesium. The only other reason why it could be leaking into the oil is if the seal has failed. There is also a little hole under the cover that leads in behind the seal and if it leaks, it comes out the hole. It gets blocked as well. Gaskets wont fix it.
« Reply #7 on: July 26, 2009, 12:15:10 pm »
I'm with 090, losing all your coolant in one ride is a bit more serious than a blown seal.
Husqvarna's have the same problems with corrosion, I've never seen one thats not effected by it.
pimpolligist16
« Reply #8 on: July 26, 2009, 12:58:54 pm »
ok thanks for the help
