Marque Remarks
Yamaha
XT500 compression testing spec's?
Topic: XT500 compression testing spec's? (Read 4533 times)
dave
July 23, 2009, 06:35:48 pm »
Could anyone please give me the spec's for a compression test of an XT500, in p.s.i please.
brent j
Darwin, NT. Suzuki tragic, RL250M TS90MX PE250B
Re: XT500 compression testing spec's?
July 23, 2009, 10:41:48 pm »
My manual says,
9.5-10.5kg/cm2 or 135-149lbs/in2 at kick starting.
It doesn't say how many time you should kick it though, I usually kick it til the needle stops rising.
hth
Brent
TT5 Matt
July 23, 2009, 11:18:28 pm »
and at wot [wide open throttle] with the motor at running temp
brent j
July 23, 2009, 11:24:13 pm »
yeah good point
dave
Reply #4 on:
July 24, 2009, 07:06:01 am »
Oh so 55psi probably isn't real crash hot
brent j
Reply #5 on:
July 24, 2009, 01:00:18 pm »
A bit on the low side yeah..............
Try some oil in through the spark plug hole then test it again, if the compression improves it's most likely rings.
Check your valve clearances and the decomp lever is free.
How well or badly does it run does it run?
dave
Reply #6 on:
July 24, 2009, 01:18:22 pm »
It ran ok several months ago but not brilliantly. Didn't blow lots of blue smoke. It has been sitting for a while. Hey Brent 55psi was after the oil went in mate
brent j
Reply #7 on:
July 24, 2009, 02:56:07 pm »
Oh...............
dave
Reply #8 on:
July 24, 2009, 04:25:46 pm »
Hey Brent thanks for the spec's, looks like I'll be doing a teardown this weekend. Cheers digger
Marque Remarks
Yamaha
