Author Topic: Maico model question  (Read 7316 times)
Offline mick25
  • Hunter valley NSW
« on: July 19, 2009, 03:06:55 pm »
A mate of mine has a maico 490 enduro 1981 or 82 model thats hes holding onto for his cousin to pick up,but when he was looking under the gear box he noticed a spare gear box lug that should be bolted to the frame,but there is no bracket on the frame and looks like there never was one there ???  all the other engine mounts look right and have not been changed , could it be a 250 bottom end with a 490 top end ??? or could it be a 250 frame with a 490 motor and gear box ???or is the 250 and 490 gear boxes the same but diffrent frames
IT was brougt un seen from ebay, i have the frame nos..  TYP GS 400T
        BAUJAHR 19
        Fahrgest.NR 2510225
        HUBRAUM 384CCM
        LEERGEW 720KG
        7-UL.6ES.GEW 225KG
The numbers on the gear box are, GT 2510028
on the barrel it has stamped R352 but there are some other numbers that are non readable ,and has a X marked on the barrell to if this helps any help would be great
Offline paul
Re: Maico model question
« Reply #1 on: July 19, 2009, 03:21:45 pm »
81and 82/ 490 and 250 cases are the same .you can put a 490 barrell on 250 cases (but you have to change a few things) the extra engine mount on the back off the cases  is when the went to 82 frame and the linkage set up bolted through the back off the engine i think ive got one some were out there give me a min and i get some pics
Offline paul
« Reply #2 on: July 19, 2009, 03:24:18 pm »
81 490 engine mx
Offline paul
« Reply #3 on: July 19, 2009, 03:26:00 pm »
81 ,250 engine
Offline paul
« Reply #4 on: July 19, 2009, 03:28:49 pm »
82/ 490 engine in a 79 frame which had engine mount on the frame but you couldn;t put a boltin anyway no room
Offline mick25
  • Hunter valley NSW
« Reply #5 on: July 19, 2009, 03:32:46 pm »
Yes looks the same as first pic ,so is it the org gear box in his frame
Offline mick25
  • Hunter valley NSW
« Reply #6 on: July 19, 2009, 03:34:58 pm »
Thanks for your help i seen you on line and you would no, hope you and your wife are well
Offline paul
« Reply #7 on: July 19, 2009, 03:36:03 pm »
come to think on it the bottom rear engine mount had a bolt through it when i pull the 82/ 490 to pieces ,but it may have been bolted through the linkage set up or just to the frame but it was definetatly had a bolt through it  i havent got that frame it went out as scrap
« Last Edit: July 19, 2009, 03:38:40 pm by PAUL »
Offline paul
« Reply #8 on: July 19, 2009, 03:37:50 pm »
thank mick im fine at the moment and she.s going in to surgery in the next 30 day
Offline mick25
  • Hunter valley NSW
« Reply #9 on: July 19, 2009, 03:47:45 pm »
So looks like its right, if the 250 and 490 81,82 cases are the same, so the bike is a 490 81 and could have a 490 or 250 gear box in it but they are the same any way so does that sound right :-\
Offline mick25
  • Hunter valley NSW
« Reply #10 on: July 19, 2009, 03:54:56 pm »
I have it all worked out now thanks paul for fast info ,will let the guy know make his day now,take care ;)
Offline paul
« Reply #11 on: July 19, 2009, 04:01:11 pm »
you engine number say gt 251 .1982 GS400/T 251 0000 GT251 0000
is it  a linkage or twin shock
but who knows maico numbers can be all over the joint as well
Offline mick25
  • Hunter valley NSW
« Reply #12 on: July 19, 2009, 07:01:04 pm »
Its a twin shocker , looks the same as ballards one at CD6, thanks again for your in put :)
« Reply #13 on: July 19, 2009, 07:15:25 pm »
My 81 maicos have that same extra engine mount sticking out on the bottom, it's normal.
Offline paul
« Reply #14 on: July 19, 2009, 07:26:57 pm »
i just checked the number on the 81 250 engine in the shed gt250  the all over the joint
