Author Topic: suzuki pistons  (Read 5983 times)
suzuki pistons
« on: July 17, 2009, 06:02:59 pm »
can anyone tell me what size a GT750 piston is (bore size)
« Last Edit: July 17, 2009, 07:40:30 pm by LWC82PE »
Offline GD66
Re: 750 waterbottle piston
« Reply #1 on: July 17, 2009, 06:10:46 pm »
GT750 were 70 x 64mm bore and stroke.
suzuki pistons
« Reply #2 on: July 17, 2009, 06:34:33 pm »
ok thanks. Do you know any suzuki road bikes with 67mm pistons? GT380???
« Last Edit: July 17, 2009, 07:40:49 pm by LWC82PE »
Offline MX?
    • Classic Bike Forum
« Reply #3 on: July 17, 2009, 06:43:25 pm »
According to the X ref:
70mm piston
Part # = 12103-31830-050
Part Description = PISTON SET
Model Count = 16
GT500A 1976 492 GT500 TITAN STREET
GT500B 1977 492 GT500 TITAN STREET
GT750-B 1977 738 GT750 LEMANS STREET
GT750A 1976 738 GT750 LEMANS STREET
GT750J 1972 738 GT750 LEMANS STREET
GT750K 1973 738 GT750 LEMANS STREET
GT750L 1974 738 GT750 LEMANS STREET
GT750M 1975 738 GT750 LEMANS STREET
T500-2 1969 492 T500 TITAN STREET
T500-3 1970 492 T500 TITAN STREET
T500 1968 492 T500 COBRA STREET
T500J 1972 492 T500 TITAN STREET
T500K 1973 492 T500 TITAN STREET
T500L 1974 492 T500 TITAN STREET
T500M 1975 492 T500 TITAN STREET
T500R 1971 492 T500 TITAN STREET
suzuki pistons
« Reply #4 on: July 17, 2009, 06:57:31 pm »
ok thats 70mm im looking for 67-69mm range.
found out GT380 is no good, pistons are 2.13"
« Last Edit: July 17, 2009, 07:41:04 pm by LWC82PE »
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #5 on: July 17, 2009, 07:31:29 pm »
67mm - you mean as an RM/PE250 alternative, or for something strange?
the 380 was  54mm x 54mm
the 550 was  61mm x 62mm
the 750 was  70mm x 64mm
does it have to be Suzuki?
e.g. the Kawasaki KDX2220 piston was 69mm  or.. what about the newer KTM's - say their SX220?
Re: suzuki pistons
« Reply #6 on: July 17, 2009, 07:39:42 pm »
just imagine a PE175 piston but bigger. Cant have port holes in piston skirt.
« Last Edit: July 17, 2009, 07:41:27 pm by LWC82PE »
Offline lukeb1961
    • PE175N
Re: suzuki pistons
« Reply #7 on: July 17, 2009, 07:47:00 pm »
some sort of crazy TS is it? 69*57 = 213cc   mmmmm :-)
DR
Re: suzuki pistons
« Reply #8 on: July 17, 2009, 08:15:39 pm »
'87 LT250R QUAD RACER 67MM X 70MM 18mm Pin ;)
Re: suzuki pistons
« Reply #9 on: July 17, 2009, 08:39:47 pm »
67mm with 16mm pin looks like an impossible combination. looks like im going to have to go to 18mm
is the LT250 piston anything special? i would assume it has some port windows/holes in the intake side of piston???
Re: suzuki pistons
« Reply #10 on: July 17, 2009, 09:38:18 pm »
just looking at a it175d piston and it takes a 16mm pin aswell and is 66mm std bore size,theres a 2/3mm difference in the compression height compered to the 185 piston and 4 mm shorter on the bottom of the skirt,you should be able to find a non reed cutout piston pre ct1
Re: suzuki pistons
« Reply #11 on: July 17, 2009, 10:19:44 pm »
i had thought about IT 175 pistons but had no idea what they looked like. since you say they have 4mm shorter skirt than TS that automatically means is a no go unless the IT piston is 4mm higher aswell. If thats the case then all i need is a 4mm spacer to lift the barrel up to correct height.
anyone got a photo of a IT 175 piston? i wonder how a DT 175 piston compares?
did you mean to say pre 81?
« Last Edit: July 17, 2009, 10:22:30 pm by LWC82PE »
Re: suzuki pistons
« Reply #12 on: July 17, 2009, 10:41:55 pm »
the yam piston is shorter in both dirrections of the piston pin that could be adjusted be machining the bottom of the barrel and as far i know the it and dt175 run the same bore and stroke even the same crank and rod and i think earlier non reed valve pistons from ct1 175's would work maybe Nathan s could shed some light on this as he's a yamaha fan and knows what goes with what
Re: suzuki pistons
« Reply #13 on: July 17, 2009, 10:57:56 pm »
ok i will see if i can investigate a CT 175 piston.
Re: suzuki pistons
« Reply #14 on: July 17, 2009, 11:34:12 pm »
there cheap as $37 ozzie landed for a 1mm over piston kit bargin of the year!!
