Author Topic: Montesa VB360/Marzocchi 35mm fork info.  (Read 6084 times)
« on: October 20, 2007, 05:28:51 pm »
Can anyone tell me the fork oil requirments, by volume (cc's) or distance from top, for the Montesa VB360/Marzocchi 35mm forks?
Lacking specifics, can anyone give a 'rule of thumb'.
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
Re: Montesa VB360/Marzocchi 35mm fork info.
« Reply #1 on: October 21, 2007, 08:02:03 am »
From the parts book.  Forks hold 260cc (8.6oz) per leg.
        Cheers, Jared
        S/W Montesa
YSS
« Reply #2 on: October 21, 2007, 10:32:48 am »
Is the fork standard or modified ?
« Reply #3 on: October 21, 2007, 05:25:15 pm »
Modified - with YSS PD valves ;D
« Reply #4 on: October 21, 2007, 05:27:16 pm »
        Cheers, Jared
        S/W Montesa
Thanks Jared
YSS
« Reply #5 on: October 21, 2007, 07:53:34 pm »
Than use 10 or 15 W oil  and have a airgap of 95-105 mm .(depending on your weight)
Fork compressed , springs out ,( PD valve in ) make sure you have cut the spacer to achieve the right preload . If the preload was correct  before you fitted the PD valve , than all you have to do is cut the spacer by the lenght of the PD valve (16 mm )
« Last Edit: October 21, 2007, 08:04:58 pm by YSS »
