Author Topic: RM125 '77 Frame  (Read 3972 times)
090
RM125 '77 Frame
« on: July 13, 2009, 07:46:02 pm »
Yes please! (I want one!)
Offline BAHNZY
Re: RM125 '77 Frame
« Reply #1 on: July 13, 2009, 07:57:02 pm »
How good does it have to be?
Rod (BAHNZY) Bahn
090
Re: RM125 '77 Frame
« Reply #2 on: July 13, 2009, 08:16:30 pm »
I would prefer good to great but show me what you have. What is wrong with it?
Offline BAHNZY
Re: RM125 '77 Frame
« Reply #3 on: July 13, 2009, 09:03:05 pm »
i'll drag it out and have a look. From memory some clown had modified the rear brake pivot bracket.
Its a 78 frame, hoeever Alpha-Sports identifies that 76/77 & 78 have the same part number.
« Last Edit: July 13, 2009, 09:04:50 pm by Bahnsy »
Rod (BAHNZY) Bahn
090
Re: RM125 '77 Frame
« Reply #4 on: July 13, 2009, 09:05:11 pm »
That would be great.
090
Re: RM125 '77 Frame
« Reply #5 on: July 13, 2009, 09:48:27 pm »
No good mate. Different animal. Must be a 77.
Offline BAHNZY
Re: RM125 '77 Frame
« Reply #6 on: July 13, 2009, 10:12:26 pm »
Interesting;
Alpha Sports who i use as an online parts resource for the Suzuki's lists the following part numbers.
http://www.alpha-sports.com/suzuki_parts.htm
1976 RM125A = 41100-41601-019
1977 RM125B = 41100-41601-019
1978 RM125C = 41100-41601-019
1979 RM125N = 41100-40200-019
Rod (BAHNZY) Bahn
Re: RM125 '77 Frame
« Reply #7 on: July 13, 2009, 10:15:38 pm »
i know where a rm125a frame is,is that any good to you?
Re: RM125 '77 Frame
« Reply #8 on: July 13, 2009, 10:19:18 pm »
i know on some suzukis around that year they changed part numbers for the frames halfway through the model run and this was usually due to an increase in footpeg pivot pin size (8-10mm) therefore more than one frame part number will come up for one model. I cant say for sure that is the case with the 77 125 though.
for 77 2 frame numbers show up.
Part # = 41100-41302-019
Part Description = FRAME
Model Count = 1
RM125B 1977
and
Part # = 41100-41303-019
Model Count = 3
RM100C 1978
RM125B 1977
RM125C 1978
several foot peg part numbers show up too
« Last Edit: July 13, 2009, 10:23:19 pm by LWC82PE »
Re: RM125 '77 Frame
« Reply #9 on: July 13, 2009, 10:22:47 pm »
The '78 tank mounts are very different because of the plastic tank. '77 tank won't go on without welding mods.
DR
Re: RM125 '77 Frame
« Reply #10 on: July 13, 2009, 10:36:54 pm »
the '77 frame will have a number somewhere between RM125-43983 to RM125-61850 ;)
3 different numbers were used for the A/B/C frames
'76  41100-41301-019
'77  41100-41302-019
'78  41100-41303-019
090
Re: RM125 '77 Frame
« Reply #11 on: July 13, 2009, 10:56:05 pm »
It is for pre 78 so 78 is no good and as Johnny O says, they are different.
No thanks mate. It must be a 77.
DR
Re: RM125 '77 Frame
« Reply #12 on: July 13, 2009, 11:02:08 pm »
not another one! :D jeez, I'm gonna have to change my A/B back to the full C cause the markets flooded :P
Offline holeshot buddy
  • sunshine coast qld
Re: RM125 '77 Frame
« Reply #13 on: July 13, 2009, 11:04:14 pm »
seen the light eh mate :-*
been drawn back to yellow ;D
i think you should sell all those maicos and hondas
and go zook ;D ;)
follow me to first turn
