Author Topic: Flat slide vs round slide carburettor  (Read 4790 times)
Offline Tex
« on: July 03, 2009, 12:48:39 pm »
In a few words (keep it simple for me please!), what is the advantages/disadvantages of flat vs round?
Is there any benefit to adding a flat slide carb to a bike that came with a round slide item?
Apologies if this has been covered before, I did a search but couldn't find exactly what I wanted...
Re: Flat slide vs round slide carburettor
« Reply #1 on: July 03, 2009, 01:16:11 pm »
Ads; Higher air speed over the venturi giving better more precise atomising which give more hp everywhere, better economy and better response.
Disads; None other than you can't use them on VMXers pre 1980 (or some similar date).
Yes, as above.
That's the muggins answer :P, over to the experts ;D.
« Reply #2 on: July 03, 2009, 03:43:56 pm »
Basicaly the H section of the flattie seals better at the sides and there is less area under the slide.The less area creates less turbulence downstream, as Graeme said higher velocity/better throttle response. Is there a benefit depends on how it's tuned, I helped a bloke tune a flatslide(PWK) on a RMX and he went back to a semi flat(PJ or was it the other way around?) because it was (for some reason) too responsive on the throttle ???
« Reply #3 on: July 03, 2009, 06:46:34 pm »
yes its pointless having a poorly tuned flatside as it could be no better than a well tuned roundslide ;)
WillsRD
« Reply #4 on: July 13, 2009, 12:11:08 pm »
G'day All,
My '83 DR500 is fitted with a CV type carb, according to info on the web it should be a round slide. How does the CV compare with the round and flat slide? The bike will only be used offroad. Which one makes for easier hot/cold starting, assuming tuning is right?
sorry for hijacking the thread!
cheers 8)
« Reply #5 on: July 13, 2009, 12:32:31 pm »
My understanding is a CV is a 'road' carburetor, with engine vaccum lifting the slide, makes it 'smoother' I suppose.They are not used on proper two stroke engines so I have no interest in them, I just pulled them off, changed jets and needles on a mates gixer when he raced it.
