Marque Remarks
Yamaha
yzB - monshock rebuild ?
Pages:
All
Topic: yzB - monshock rebuild ? (Read 11158 times)
BONEHEAD
Re: yzB - monshock rebuild ?
Reply #15 on:
November 03, 2007, 09:54:21 am »
YSS, i have a good yz465 shock , i found it at the local wreckers, no shit its like new, anyway what is the estimated cost for servicing this shock, your time is much appreciated. CHEERS BONEHEAD
YSS
Reply #16 on:
November 03, 2007, 10:36:00 am »
We normally charge $90.00 +GST. There also options with a better Seal and piston set up.
Last Edit: November 03, 2007, 10:39:33 am by YSS
BONEHEAD
Reply #17 on:
November 03, 2007, 01:52:31 pm »
MMM, better seal and piston option? estimated cost please as im very interested, will you need to know anything about my weight if i do decide to go with the piston option, i have been on holidays and put on a few kilos
mmm
my mate has a shock that needs re doing as well ,probably post them of together. cheers BONEHEAD
YSS
Reply #18 on:
November 03, 2007, 03:15:37 pm »
assuming the shaft is 14 mm and the body is 46 mm , the seal block complet is 72.00 , the radial piston is 58.00 , the piston ring is 15.00 and the shims are 2.00 each as needed for your weight.
BONEHEAD
Reply #19 on:
November 03, 2007, 03:22:38 pm »
not to sure on the dimensions but i will send the shock anyway after the end of season race next weekend your prices are reasonable and your help is appreciated, i will ring you when there in the post and have lost the 5 or so kilos
CHEERS BONEHEAD
[attachment deleted by admin]
Last Edit: November 03, 2007, 03:34:21 pm by BONEHEAD
Pages:
All
Marque Remarks
Yamaha
