Author Topic: Tyre Pressure  (Read 4361 times)
Offline Graham
  • Fast TT meets Drunks Hill
Tyre Pressure
« on: June 29, 2009, 05:16:03 pm »
Hi can someone help,first time at dirt track am running a Michelin trials tyre and Michelin knoby front
what tyre pressures should I run ???
Gosh its a shame a slow 4 stroke trail bike can go so Fast !!
Offline mike1948
  • Margate, QLD
Re: Tyre Pressure
« Reply #1 on: June 29, 2009, 05:57:09 pm »
From many years ago, it depends on the track surface, however a good starting point is similar to MX - 15 front & rear, then work from there.  Unlike MX, you may have to increase pressure, if the track is very hard.
Re: Tyre Pressure
« Reply #2 on: June 29, 2009, 06:08:26 pm »
The dirt track guys run 8 - 10lbs in those michelin trials tyres. Probably run the front at about 12-14lbs, same as mx.
Offline Graham
Re: Tyre Pressure
« Reply #3 on: June 29, 2009, 06:14:03 pm »
Thanks for that, now I known where to start :D
Offline oldyzman
  • 250 two stroke!
Re: Tyre Pressure
« Reply #4 on: June 29, 2009, 09:21:49 pm »
Hey Graham,
Are you going to nepean for your first race this sunday?
Brett
Offline Graham
Re: Tyre Pressure
« Reply #5 on: June 29, 2009, 09:32:59 pm »
 Hi oldyzman, no got the Double the dirt here in Brisbane 11/12 July, thought I might give the dirt track a go, have a Kawasaki twin, pre 78 and an evo 250
Offline oldyzman
  • 250 two stroke!
Re: Tyre Pressure
« Reply #6 on: June 29, 2009, 09:45:11 pm »
Good for you graham, I am goin to have a run at Nepean this sunday. with a RM125S and a YZ125E
Not sure about the classes (events) though
Brett
Re: Tyre Pressure
« Reply #7 on: June 29, 2009, 11:58:04 pm »
FWIW , i run 8 psi, if its cold weather i start on 10 psi, after a lap they seem to come on, so im thinking as the walls bend over they heat up and stand up anyway., when i come in there around 12 psi, the michelins like to runover onto the walls and on a speed corner they should be almost like a banana.
too much pressure and they seem to drift out/slip away from you but dont get any drive, you just get the wheel spin.
IF you find you have to put more than 12psi in cold  to get it to step out and your running short track, put an angle on your rear, winding your outbound wheel adjuster out only, an extra few turns
« Last Edit: June 30, 2009, 12:00:27 am by Freakshow »
Offline allan hughes
Re: Tyre Pressure
« Reply #8 on: June 30, 2009, 08:41:08 am »
VERY IMPORTANT
TO RUN HEAVY DUTY TUBES
THAT 20 YEAR OLD
STANDARD TUBE WONT HANDLE LOW PRESSURES
