Author Topic: over bore  (Read 5611 times)
Offline k2000x
over bore
« on: June 27, 2009, 08:18:43 pm »
what size is a standard bore on a vr250 cylinder and is it possible to bore it to take a 75mm piston
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
Re: over bore
« Reply #1 on: June 28, 2009, 01:23:49 am »
Standard bore size is 70.00mm.  Taking it out to 75mm might be a bit dicey!
73mm is the largest I have seen on a VR.
Re: over bore
« Reply #2 on: June 28, 2009, 09:07:07 am »
Does the iron liner press out?
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
Re: over bore
« Reply #3 on: June 28, 2009, 11:41:21 am »
Yep, all Montesa's prior to 1985 had press in liners.
runutz698
Re: over bore
« Reply #4 on: June 28, 2009, 01:06:08 pm »
Solo montesa has quite a few NOS liners!!! Just thought it would help if you wanted to take back to orginal.
Nutz
Re: over bore
« Reply #5 on: June 28, 2009, 07:38:03 pm »
Does the liner form the inner wall of the transfer or is there aluminium there?
Re: over bore
« Reply #6 on: June 28, 2009, 09:50:33 pm »
The liner is the inner wall of the transfer.
Offline JC
Re: over bore
« Reply #7 on: June 29, 2009, 01:02:43 pm »
OD of VR liner is 80.5mm. Running oversize pistons to 3mm liner thickness was common in the day. Its what Wiseco seemed to work on. That would mean 74.5mm piston. Liner material of VR is extrememly hard when you try to bore it, which probably indicates good quality. So it may be strong enough to take 75mm piston.  (Lyall O'Brien once told me its Rockwell hardness rating but I've long since forgotten it)
Offline k2000x
Re: over bore
« Reply #8 on: June 29, 2009, 04:15:16 pm »
hi guys just wanted to know as ive got my hands on a jet ski piston and with few mods looks like it could work its 75mm has 16mm pin and the pin centre to deck/top of piston is almost the same..i have a old cylinder that i was going to use so should i try it
Re: over bore
« Reply #9 on: June 30, 2009, 10:09:22 pm »
Gotta be worth a try!
Offline JC
Re: over bore
« Reply #10 on: July 01, 2009, 09:11:31 am »
Yeh, I reckon so too, esp since you have a spare barrell. And the liner can be replaced anyway.
Ossa liners were 2.75mm thick on std bore.
VR liner is full circumference under the transfer cut-outs, which will give a little more support where its needed too.
75 bore gives 283cc
« Last Edit: July 01, 2009, 04:32:39 pm by JC »
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
Re: over bore
« Reply #11 on: July 01, 2009, 03:16:29 pm »
Don't forget to have the head fly cut to the new bore size.
Re: over bore
« Reply #12 on: July 01, 2009, 11:51:11 pm »
Offline k2000x
Re: over bore
« Reply #13 on: July 02, 2009, 01:27:20 pm »
found a better piston to try...440 jet ski big bore piston 72.5mm this sounds alot safer than the 75mm
Re: over bore
« Reply #14 on: July 02, 2009, 02:37:04 pm »
Have you got the piston or just sifting through specs? Something to check is that the piston has no cutaways in the rear skirt.
I better say it
"but will it work?"
 ;D ;D ;D
