Author Topic: YZ125C rear sprocket options  (Read 2772 times)
Offline brent j
« on: June 25, 2009, 09:48:21 pm »
Is there a steel sprocket available, possibly from another model, that will fit a YZ125C.
Not so much worried about weight but trying for a longer life
The standard sprocket is dished and the owner doesn't really want to make a spacer to fit a flat sprocket.
Brent
« Last Edit: June 25, 2009, 09:56:16 pm by brent j »
Re: YZ125C rear sprocket options
« Reply #1 on: June 25, 2009, 10:26:51 pm »
MX125/175A has a dished steel sprocket. They're probably harder to find than the YZ alloy sprocket though - at least there's after-market dished alloy sprockets out there...
The spacer is a better option. DT175 sprockets would have to be THE most readily available sprockets in the world.
Offline brent j
« Reply #2 on: June 25, 2009, 10:33:25 pm »
Thanks nathan,
I don't know why he's worried about the spacer, I'll have to make the bloody thing!
Truth is I get to ride the bike often enough so I certainly don't mind
Brent
« Reply #3 on: June 25, 2009, 11:07:59 pm »
:D
Other options:
YZ125X rear wheel will go straight on, and takes a flat sprocket. Rim is a straight walled lipless type, unlike the C's externally lipped rim (if that matters).
YZ125D/E/F, IT175D/E/F or monoshock DT125/175 rear hub can be machined down to the 125X dimensions. Obviously these are a lot easier to find than YZ-X wheels.
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #4 on: June 26, 2009, 12:11:22 am »
very easy Brent,
roll on down to your Yamaha dealer and tell him you want a sprocket for the good old Ag 100.
available in either 47t or 51t in good old hardened steel.
only catch is, the MX/YZ style has a 6 bolt pattern while the Ag has a 4 bolt pattern.
bolt P.C.D. is the same and so is the centre hole and dish.
i just bolt the 2 sprockets together then drill through the 6 bolt one into the other. a 10minute job with the right drill press.
thats what i use on my little MX125 and it's the same rear hub as the YZ125c.
« Last Edit: June 26, 2009, 08:41:05 am by vandy010 »
"flat bickie"
Offline brent j
« Reply #5 on: June 26, 2009, 07:23:22 pm »
Thanks guys,
There's a DT175 at the local dump shop for SFA. It's got hubs so I'll grab that this weekend.
And we now have a few options
Brent
