Author Topic: Yamaha dt/rt360  (Read 3060 times)
gawmon
Yamaha dt/rt360
« on: June 25, 2009, 05:56:47 pm »
hi looking for a carby for dt/rt360 34mm bolt up type has drain plug on angle with jet thanks graham qld
Re: Yamaha dt/rt360
« Reply #1 on: June 25, 2009, 05:58:16 pm »
If its a flange mount type, then its RT1, not DT360.
And I can't help, 'cause I'm looking for one too....
Re: Yamaha dt/rt360
« Reply #3 on: June 25, 2009, 10:30:45 pm »
34mm was RT-MX only, hence the rareness.
My DT1 runs a 30mm RT1 carb, but it runs out of breath - a 34mm one would be better.
Standard DT1 carb is 26 or 28mm (I can't recall right now - I think 28).
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: Yamaha dt/rt360
« Reply #4 on: June 26, 2009, 12:14:27 am »
i've got one from a DT360 you could have but i don't think they're 34mm. more likely 32mm with a rather small flange on the airbox side. i'm in Brisbane if that helps, just let me know if it's what you want and it's yours.
"flat bickie"
gawmon
Re: Yamaha dt/rt360
« Reply #5 on: June 28, 2009, 02:20:25 pm »
hi vandy let me know how to contact you thanks
Offline vandy010
Re: Yamaha dt/rt360
« Reply #6 on: July 14, 2009, 09:30:24 am »
long overdue personal messege sent Gawmon. my apology for the delay
"flat bickie"
