Author Topic: cz 400 pistin ID  (Read 3682 times)
Offline HL400
cz 400 pistin ID
« on: June 22, 2009, 06:26:57 pm »
Hi cz experts I have just pulled down my 1973 cz 400 and I am trying to identify the piston so I can organise a set of rings, the piston measures 82.25 and on the top it has 2AX stamped in it, so what brand is it ??? and where will I find a set of rings to suit.  H
Offline hampster
Re: cz 400 pistin ID
« Reply #1 on: June 22, 2009, 08:49:59 pm »
hi H,
It must be rebuild your 400 month, does the piston have any markings on the inside?
Chris.
« Reply #2 on: June 22, 2009, 08:58:03 pm »
hi
82.25 is not a gen cz piston size
check
czmadness web page has manuals on it to tell you eveything i am rebuilding my 72 cz400 from them and help from this forum and members of usa cz forum
jim
Offline HL400
« Reply #3 on: June 22, 2009, 09:06:22 pm »
Hi Chris not a lot of numbers on the piston, on the inside all I can find is a number 7 cast in,
H
Offline Drakie
« Reply #4 on: June 26, 2009, 10:04:24 am »
The piston is a 2nd oversixe stock CZ. they are all marked _ 1 2 3, A B C, X Y Z. So a first oversize could be 1AX, 1AY, 1 Az, 1BX, 1BY, 1BZ, 1CX etc. They are sized to the original bore taper. Very accurate engineering. Any second over rings will fit, no I don't have spares,
D.
« Reply #5 on: June 26, 2009, 10:38:54 am »
according to the on line manual 82.16 is the size of 1st oversize 2nd oversize 82.41
82.25 is the bore size 82.50 is the limit for 1st over
Offline hampster
« Reply #6 on: June 27, 2009, 01:29:11 pm »
D.
Do you know the recommended clearance from bore to piston?
Chris.
