Author Topic: TS185 wheels in SP/DR?  (Read 2553 times)
TT
« on: June 21, 2009, 12:44:45 pm »
Can anyone tell me if TS185 wheels might fit in a DR400 or SP370?
A long shot, I know...............  :)
thanks in advance.
Re: TS185 wheels in SP/DR?
« Reply #1 on: June 21, 2009, 01:26:16 pm »
i know TS250 rear wheel might as they use the same sprockets as SP370
SP370 rear axle is common to 59 different models of suzukis.
TS185 will have a rim too narrow for SP. 185 rim would be 1.85. You would want a 2.15 for a 370
Offline cloggy
« Reply #2 on: June 22, 2009, 06:29:51 am »
Even if it fits, would it be strong enough?
Offline cloggy
« Reply #3 on: June 22, 2009, 06:34:06 am »
Oh and the DR uses a bigger wheel spindle  so you'll need spacers in the swingarm slots if you are using a standard swing arm. More to the point, you'll need to check how far off centre the respective gearbox sprockets are. The DR and SP are identical
DR
« Reply #4 on: June 22, 2009, 07:52:37 am »
Tony I'd reckon the wheels would be strong enough but I can't say the same about the braking performance ;)
TT
« Reply #5 on: June 22, 2009, 08:03:41 am »
Thanks fellas.
I really only planned to use the rear hub, so rim width and braking performance wouldn't be important. Sorry, should have been more specific.
« Reply #6 on: June 23, 2009, 07:31:16 pm »
SP 370 rear spoke set is the same as on all these if thats any help
DR370C 1978
DR370N 1979
DS250T 1980
SP370C 1978
SP370N 1979
SP400T 1980
TM250J 1972
TM250K 1973
TM250L 1974
TM250M 1975
TM400J 1972
TM400K 1973
TM400L 1974
TM400M 1975
TM400R 1971
TS250A 1976
TS250B 1977
TS250C 1978
TS250J 1972
TS250K 1973
TS250L 1974
TS250N 1979
TS250R 1971
TS250T 1980
TS250X 1981
TS400A 1976
TS400B 1977
TS400J 1972
TS400K 1973
TS400L 1974
TT
« Reply #7 on: June 23, 2009, 08:34:20 pm »
That might be useful info, Leith.
Thanks!
« Reply #8 on: June 23, 2009, 10:22:51 pm »
i could list all the 59 bikes that use the same axle but it is a big list. best to email it if you want to see.
