Author Topic: TS185 parts 1980  (Read 1649 times)
TwoTees
TS185 parts 1980
« on: June 21, 2009, 12:03:51 pm »
Hi.
I picked this up the other day and got the bits I needed. If there is something you see that you need let me know with a reasonable offer to cover my time and Ill get it to you via the post or pick it up from Gordon in Canberra.
The rims and forks are almost rust free. rear hub has had 2 sprocket bolts drilled right through with nuts on the end. Bore measures 64.3 at the widest point. plastic is painted but in good shape. bottom end feels ok. kick start lever welded on. Seat base good, cover has a couple of small poke holes.
I will be quite busy this coming week but the following week I will have some time to disassemble and post.
Cheers, Chris
DR
Re: TS185 parts 1980
« Reply #1 on: June 21, 2009, 03:26:31 pm »
hmmmm..the seat and shocks would definately help finish off my 185 :-\ hold those items Chris, I'll be in touch ;)
TwoTees
« Reply #2 on: July 25, 2009, 11:00:07 pm »
Here is a photo of what maybe left.
All cheap,need it gone.
Cheers, Chris
Offline Tim37
  • Its an investment ...had to buy it !
« Reply #3 on: July 29, 2009, 10:57:09 pm »
Hi need a ts ignition system fiywheel stator cdi box and coil ....let me know the price ..cheers Tim
