Author Topic: cd 6 buy  (Read 7336 times)
Offline hampster
cd 6 buy
« on: June 09, 2009, 09:35:09 pm »
hi,
Just got back from cd 6, had a ball can not believe the amount of bikes out for the weekend.
The only problem i have is a new bike after some trailer shuffling i have it back in bris vegas.
I think its a 71 frame with a 250 bottom end and a 400 73 top end ?
well out goes the xl 350 for the nats and the 400 is in.
Being new to the cz family just trying to obtain some information to get the bike back on the track.
The bike it self seems to be 90% the running gear seems ok and it has some good after market plastics, the only items  which i need to get it running is some new electrics, it has a it 465 cdi set up in but it does not look to be in good nick  i would like to change it out for a complete new set up.
I have ordered a work shop manual a clymer hope it will be a help.
Have started the read the cz forum it has a lot of information so i hope i will up and running quickly.
Thanks Chris.
« Last Edit: June 09, 2009, 09:47:15 pm by hampster »
Re: cd 6 buy
« Reply #1 on: June 09, 2009, 11:00:34 pm »
chris
400 top ends wont go on 250 bottom ends.
web site cz madness will give you all the cz manuals you will need for free.
frames never changed much from 70 to 73.74 had a different swing arm and 75 were red
jim
1973 cz 250
1971 cz400
Ji Gantor
Re: cd 6 buy
« Reply #2 on: June 10, 2009, 05:13:20 pm »
Hi hampster,
Where are you in Brisbane?
Ji
Offline shortshifter
  • Sunshine Coast QLD
Re: cd 6 buy
« Reply #3 on: June 10, 2009, 06:12:53 pm »
Chris yeah I think the 980 prefix on the case is a 250.I think you did tell me but did you measure the piston,the 250 piston should be around 69/70mm.I'd be interested in your old 465 ignition if you dont want it.Ther has been a bit of discussion about points and new cdi ignitions which might be the way to go.Brad put one in his 400.That thing was a great buy!
Re: cd 6 buy
« Reply #4 on: June 10, 2009, 06:37:54 pm »
before youtake off the ignition can you take some pics of how it fits.also some step by srep of how the ignition fits but as you take bits off
jim
090
Re: cd 6 buy
« Reply #5 on: June 10, 2009, 06:55:47 pm »
Buy of the weekend!
Lucky for you there wasn't enough room on the truck!!
Buy an electronic ignition, the stator windings are their weak point.
Welcome my brother from another mother.
Offline Bamford#69
Re: cd 6 buy
« Reply #6 on: June 10, 2009, 07:38:13 pm »
Hi,
Chris , the eng. No. is not the real CZ stamps , never ever been stamped on the right side , no biggy though, When you want to split the cases , Iv'e got a set case splitters/pullers to lend .
Check to see if they are matching cases,  stamped on each half under the crank, outside , three  digits , dont bother trying to build an unmatched set of cases until they are checked, by an engineer to guarantee they have "line bored"
Iv'e got an old spare parts book (FREE) , No you don't have to get a TATOO to belong  to the brotherhood .
Offline holeshot buddy
  • sunshine coast qld
Re: cd 6 buy
« Reply #7 on: June 10, 2009, 08:26:23 pm »
hey chris did they tell you
about the secret handshake
and the goat ;D
follow me to first turn
Offline hampster
Re: cd 6 buy
« Reply #8 on: June 10, 2009, 09:15:23 pm »
Hi,
Have done more removal of the motor it is a 400 the bore is around the 84 mm mark on fourth over size new piston bored and honed, the porting matches the cases.
it also has a new rod installed and new bearings in the gear box the gears look new to me with the smell of packing grease still on them?
I have got my tattoo and the goat, the goat is a long hair does this make the gods happy.
Re: cd 6 buy
« Reply #9 on: June 10, 2009, 09:29:10 pm »
hi
can you tell me the engine no and i can tell you the year.i am restoring a 400 at the moment and it is a 1971 all 400s have 4 speed boxes.if you want you can pm me the no.
jim
Re: cd 6 buy
« Reply #10 on: June 11, 2009, 08:25:42 am »
Did anyone meet the guy with the trailer full of CZs,an underpipe canam and CR 125.These bikes looked well used but much loved and were wearing no 1 plates.I tried to catch him but never connected.
Re: cd 6 buy
« Reply #11 on: June 11, 2009, 08:34:14 am »
Just reading another thread:John Boag CZ nut.Apparently he was worked on by both Brad and Ji to try and separate him from one or other of his bikes but resisted all attempts.
Offline JC
Re: cd 6 buy
« Reply #12 on: June 12, 2009, 10:29:01 am »
Hampster, is this the one you bought? Sure looks nice.
« Last Edit: June 12, 2009, 12:23:50 pm by JC »
Ji Gantor
Re: cd 6 buy
« Reply #13 on: June 12, 2009, 10:31:44 am »
If he purchased that for $3500.00 or less he has done well.
Ji
Re: cd 6 buy
« Reply #14 on: June 12, 2009, 10:38:51 am »
yep thats it and it was for less ;D
