Author Topic: Identify guard ?  (Read 2336 times)
Offline YUMASTEPSIDE
Identify guard ?
« on: June 09, 2009, 08:09:37 am »
This guard came on one of my PE175 parts bikes..........is it some model PE or an aftermarket ? It's slightly shorter than a Preston Petty,but exactly the same shape and size and has moulded mounts for a triangular shaped taillight.
                      Roger
Re: Identify guard ?
« Reply #1 on: June 09, 2009, 08:49:20 am »
it might be an earlier version of a Petty with just the rear section cut off, or if could be a european copy such as Stilmotor, M.Robert. Falk or UFO. There were and still are a couple Manufacturers who were making fenders in particular that rear one that appeared to be copies of preston pettys guards or was it the otherway around?
are there any markings under the guard?
im sure i have pictures i have printed off of that exact guard wiht those lens mounting but i would have to try and find that info i have printed off.
This is a Stilmotor A43
« Last Edit: June 09, 2009, 08:51:58 am by LWC82PE »
« Reply #2 on: June 09, 2009, 12:52:38 pm »
no marks on the inside and it hasn't been cut off
                Roger
« Reply #3 on: June 09, 2009, 01:19:35 pm »
heres the UFO one
thats strange if it hasnt been cut off or shortened at the bottom under the light
Offline dkupf
  • Kinka Beach Qld
« Reply #4 on: June 10, 2009, 04:58:01 am »
Yep I have a couple of these old preston petty guards and there all have the end cut off. They used to split on the end so we just cut them off. On the old Hodakas you had to cut the front of them off to make them fit into the inner guard. Darcy
« Reply #5 on: June 10, 2009, 07:47:42 am »
your'e probably right, every one I have has been cut ,ground or mutilated in some way.
                   Roger
