Author Topic: Suzuki CCI oil pump  (Read 15236 times)
Offline ss2fly
Suzuki CCI oil pump
« on: June 05, 2009, 01:18:00 pm »
Are these all the same pump across the range of TC / TS / TM / TF / 100 / 125 / 185 / 250 / 400.......
The one i have is a MIKUNI with 2 feed tubes to the cylinder and l/h main bearing and is seized to the point where the worm drive on the input shaft is stripped!! >:(
I need a good one, (amont a growing list of bits needed  ;D), there are a few available over here in NZ but off different bikes, so I need to know if they are all the same or not...
Im keeping the CCI system intact as Suzuki intended and am NOT interested in going the premix way...
Andy
WANTED : TM125 EXHAUST, ANY CONDITION!!!
WANTED : YAMAHA YZ250J ANY CONDITION!!!
Offline ss2fly
Re: Suzuki CCI oil pump
« Reply #2 on: June 05, 2009, 02:17:15 pm »
Thanks CG, I will go see my not so friendly wrecker tomorrow.... fleabay is not so good for us kiwis as the exchange rate plus shipping stuffs it really  :(
Offline ss2fly
« Reply #3 on: June 07, 2009, 06:11:25 pm »
Well I went and saw my wrecker....
All he has is a few very similar pumps with push-in brass fittings instead of the small banjo type I have  :(
As well as this, they all seem to have only one feed line comming off the pump, the right side outlet seems not to be used...???? :o
Can I either tap these two fittings to accept my banjos (if the right side one even works.....) or simply use the drive and small other parts and fit these to my existing stuffed one ( basically use my pump body with the replacement pump internals???)
Dont even bother suggesting premix.... Im not interested..... :D
Such a common part but what a pain in the arse!
« Reply #4 on: June 07, 2009, 06:21:32 pm »
i think its best to use the right pump for the right bike and no modify something to suit. these pumps are calibrated to feed a specific amount of oil at a time and i certainly would not go messing with them. The life and performance of the motor depends on the correct oil pump in good working order. Im sure theres some on ebay. Dont US sellers ship to NZ?
Offline ss2fly
« Reply #5 on: June 07, 2009, 06:27:25 pm »
Yes they do ship to NZ but the cheapest price I had for shipping was $31.00 US !!!!!!!!!!!!!!!! for a lousy pump!!!!!
I tend to agree, the right part for the right bike.......there must be some around somewhere.
From a curiosity point of view, I might grab one of the ones from the wrecker and see what bits actually interchange.
Its only 2 parts that need to be replaced....
Offline matcho mick
    • Moto Tumbi
« Reply #6 on: June 07, 2009, 07:46:14 pm »
if the pump fits on,why not just set it up to provide more sooner??,(advance the cable??) put a T piece in the single output line,main bearing wouldn't require that much would it??,justa thought ;)
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #7 on: June 07, 2009, 07:52:32 pm »
I have a rooted RV125 bottom end and it has all the oil pump stuff still attached, I'll look into pulling it out to see if it's any good. If it is serviceable you can have it for free + postage.
Ban BLACK rims NOW
« Reply #8 on: June 07, 2009, 07:54:24 pm »
here is a list of NZ wreckers. Ive used 'buckets and bits' wreckers before
http://www.motorcyclewrecker.co.nz/
also suss out who selling what on www.trademe.co.nz
Offline ss2fly
« Reply #9 on: June 08, 2009, 03:31:28 pm »
Thanks guys....
The single feed to the engine cannot be split to feed both points as it wont provide enough oil at full throttle and I DONT want it seizing at 10,000 rpm !!!!
CG, you are an absolute gem! I am going to the wreckers tomorrow afternoon after work and will get a pump to see if I can make 1 out of 2...... I will let you know if I need the pump mate, thanks very much.
Trade me has one at the moment but it is the wrong type as are all the others i have come across so far....
Fun and games with VMX and old bikes, its half the attraction..... ;D
Andy
Offline cyclegod
  • Sunny PERTH W.A
« Reply #10 on: June 08, 2009, 06:57:42 pm »
Here's what I dragged out of the RV bottom end, you can have the oil lines too if needed.....
Ban BLACK rims NOW
Offline ss2fly
« Reply #11 on: June 08, 2009, 07:09:20 pm »
THATS IT!!!!!!!!!!!!!!! THATS IT!!!!!!!!!!!!!!!!!!!!!!!THATS IT!!!!!!!!!!!!!!!!!!!!!!!!
To hell with the expense!  ;D Send all of it CG
I'll PM you my details etc....
WAA HOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ;D ;D ;D ;D
Offline cyclegod
  • Sunny PERTH W.A
« Reply #12 on: June 08, 2009, 07:15:25 pm »
No probs, I'll stop by the Post office and pick up a padded bag tomorrow and sort out how much it will cost to airmail to NZ.
Ban BLACK rims NOW
Offline ss2fly
« Reply #13 on: June 08, 2009, 07:19:37 pm »
Your truly a good bastard!
« Reply #14 on: June 08, 2009, 07:28:48 pm »
i just had a look and the 72 oil pump is the same as these
Part # = 16100-28010
Part Description = PUMP ASSEMBLY,OIL
Model Count = 13
TC125A 1976
TC125B 1977
TC125J 1972
TC125K 1973
TC125L 1974
TC125M 1975
TS125A 1976
TS125B 1977
TS125J 1972
TS125K 1973
TS125L 1974
TS125M 1975
TS125R 1971
the RV125 pump is only unique to that model. dont ask me what the difference is
Part # = 16100-27310
Model Count = 5
RV125A 1976
RV125B 1977
RV125K 1973
RV125L 1974
RV125M 1975
« Last Edit: June 08, 2009, 07:34:35 pm by LWC82PE »
