Author Topic: TS/TF 185 headlight brackets  (Read 1806 times)
« on: June 02, 2009, 09:14:43 pm »
im looking for some TS/TF185 headlight brackets or any other similar suzuki headlight brackets to suit 32 or 33mm forks
[email protected]
« Last Edit: June 02, 2009, 09:17:08 pm by LWC82PE »
Re: TS/TF 185 headlight brackets
« Reply #1 on: June 02, 2009, 09:44:58 pm »
what year and do you need the chrome bits that go with them?
TT5 Matt
« Reply #2 on: June 02, 2009, 09:52:08 pm »
not sure what you mean by chrome bits but im after something that looks like this
http://ozvmx.com/community/index.php?topic=7623.0
doesnt have to have square hole though
around 77-79
« Last Edit: June 02, 2009, 09:54:51 pm by LWC82PE »
« Reply #3 on: June 02, 2009, 10:09:32 pm »
so you want ER185 h/light brackets?do you need a h/light to take a 5 and 3 quarter light as well?
matt
« Reply #4 on: June 02, 2009, 10:22:15 pm »
ER185 doesnt have headlight brackets. The light is mounted inside a shell. i dont need that.
Headlight will be 5&3/4, probably 82 DR250 if i can find one. I dont know what size light the 77-78 TS185 is but if the brackets are a not quite wide enough i will just modify them a to fit a wider headlight. Fingers crossed!
