Honda
MT 250 PETROL TAP
Topic: MT 250 PETROL TAP (Read 1904 times)
jimg1au
MT 250 PETROL TAP
May 31, 2009, 10:51:34 pm »
HI
i want to put a steel tank on my race cr250m but there is no petrol tap what models fit and dose any one have 1 mine is broken off at the bowl
jim
albrid-3
Re: MT 250 PETROL TAP
June 01, 2009, 07:54:28 am »
Jim, Would a cr125m tank fit on to a cr250m frame. should look ok. pick the 125 tank up cheaper, ct tank.
DR
June 01, 2009, 08:19:52 am »
I've a couple of spare CT125 tanks but both have dents. The fuel tap maybe the same ??
jimg1au
June 01, 2009, 11:12:46 am »
i have 2 mt tanks both without petrol taps the 125 tank is smaller in length will be a gap between tank and seat
doc will check out ct1 taps
squirtmoto
June 02, 2009, 08:18:37 pm »
Motorcycling Specialties (MCS) make after market fuel taps for both Yamaha and Honda, check with your local bike shop and ask to see the catalouge. it contains the thread datails to compare with your tank. RRP is approx $30-35.
Quicksilver
June 04, 2009, 08:08:28 am »
Jim.
CT125 tap wont go anywhere near fitting however CT125 Tap is excellent replacement for XR75 K4 and K5.
To fit your MT tank on CR you need to trim sides of rear mounting bracket or seat wont slip up into position. I dont have one here to compare against but I am fairly sure KO K1 XL350 taps are same as MT.
jimg1au
June 04, 2009, 09:07:28 am »
i now have a plastic replacement tank for my cr250 its red but its for the race bike
Honda
MT 250 PETROL TAP
