Author Topic: Nothing wrong with Maico drum/shoe front brakes  (Read 2652 times)
« on: May 28, 2009, 01:25:02 pm »
A small amount of effort in general approch will make/improve, any front expanding shoe type brakes. Including Maico. Especially Maico. ;D
As with Maico clutches a little bit of knowledge and thought can go a long way. ;D
« Last Edit: May 28, 2009, 01:27:52 pm by MICK-DE »
Offline mxmaniac
Re: Nothing wrong with Maico drum/shoe front brakes
« Reply #1 on: May 28, 2009, 04:48:39 pm »
any tricks to make a 490 clutch any lighter? a certain model brake arm etc?
Maico's, the only way to go.
kristan
« Reply #2 on: May 28, 2009, 11:08:11 pm »
yeah, just put everything how it should of been originally. IE. magura levers, good cable correctly routed and the right amount of springs, friction plates and steels. and that is about all you can do.
suppose you could try a hydrulic arangement, but the action on the clutch is verry long.
Just be thank full it doesent slip!
As for the front brake, i agree. if you set them up right the work well
