Author Topic: RM125M throttle valve/slide/needle #2.5 c/a  (Read 1303 times)
DR
« on: May 23, 2009, 04:25:24 pm »
I'm in need of an RM125M or TM100L/M throttle valve/ carb slide and needle. Same diameter (29.5mm) as TM125 but I need a #2.50 and 2.0 cutaway. Pretty sure these were all the heavier chromed brass type slides and not the light alloy ones. Also the #5D37-P needle if it's still in the slide would be a bonus as would the 'high top' carb cap(35mm ID). New or used. reply here or email me at [email protected]
