Author Topic: Yamaha YZ/IT TLS brake help  (Read 1859 times)
« on: May 23, 2009, 01:05:41 pm »
can any owners of a TLS brake on a YZ or IT help with wtih these measurements?
measurements 'C' & 'D' - center to center of pivots/pins
measurement 'A' - center of  lower cam to center of pivot (red arrow pointing to 'point 1') measuered inline with blue line
measurement 'B' - center of pivot pin to center of hole in end of lever for cable ( from point 1 to point 2) I would like this measurement measured in line with the blue line and inline with the green line (on an angle) to see if they are they are the same or not. So basically if you could imagine the lever was straight and there was a straight line between all 3 points (blue line) if measuement 'B' would still be the same as it is just measuring inline with the green line
Thanks for your help
« Last Edit: May 23, 2009, 01:20:44 pm by LWC3077 »
Offline KB171
Re: Yamaha YZ/IT TLS brake help
« Reply #1 on: May 23, 2009, 02:34:28 pm »
A=30
b=60
c=30
d=110  Thats on an IT250K,
cheers KB
« Reply #2 on: May 23, 2009, 02:56:20 pm »
was 'B' -60mm the same no matter if measured along green line and blue line?
« Reply #3 on: May 23, 2009, 03:04:20 pm »
Isn't "D" variable?
The linkage is adjustable isn't it?
« Reply #4 on: May 23, 2009, 03:36:45 pm »
thats a good point.
it probably wont matter though, the most important measurements i needed were the lever lengths.
« Last Edit: May 23, 2009, 04:40:34 pm by LWC3077 »
