Author Topic: 84 cr 500  (Read 6514 times)
Offline 490 tez
84 cr 500
« on: May 15, 2009, 07:18:39 am »
 ???any ideas at the end of the start finish straight she blubbers like fuel starvation but not every lap float leavel looks good ??????
big bore two strokes rock!!!!!!!!
albrid-3
Re: 84 cr 500
« Reply #1 on: May 15, 2009, 07:45:45 am »
is tha tank clean, and the filter in the tap clean.
Offline 490 tez
Re: 84 cr 500
« Reply #2 on: May 15, 2009, 08:39:28 am »
tank is clean will check filter thank you  ::)
Re: 84 cr 500
« Reply #3 on: May 16, 2009, 01:31:12 pm »
While your there TEZ check your fuel cap breather hose, some times they can block and cretae vacume in tank, which prevents fuel flowing properly.
Offline 490 tez
Re: 84 cr 500
« Reply #4 on: May 17, 2009, 01:48:21 pm »
thanks guys been away will check this week
Offline maicoman18
Re: 84 cr 500
« Reply #5 on: May 17, 2009, 08:29:36 pm »
Is there a wire mesh filter fitted to the bottom of the main jet in the carbie? Check if it is blocked or as in my case, it was the wrong type and when I tightened the carbie drain plug, it compressed the mesh and starved the engine of fuel at full throttle
Ed
Offline 490 tez
Re: 84 cr 500
« Reply #6 on: May 26, 2009, 07:17:25 pm »
 ;) arrr i found out a 3 possi fuel tap off and what i thought was on but was only like half on and turn it all the way around holy shirt heaps of fuel came out end of probs i hope she ran sweeet on the week end  ;D ;D
Offline frostype400
Re: 84 cr 500
« Reply #7 on: May 26, 2009, 07:46:23 pm »
sounds good they tend to run better with fuel to them ;D easy fix looks a beast thanks Michael. :)
1971 tm400 and PE's
Re: 84 cr 500
« Reply #8 on: May 26, 2009, 07:53:58 pm »
Pity they don't have a "Red Faced" Icon.
husky61
Re: 84 cr 500
« Reply #9 on: May 27, 2009, 08:14:28 am »
MMMM
Offline 490 tez
Re: 84 cr 500
« Reply #10 on: May 27, 2009, 11:00:40 am »
yes the tap has off and on which is straight down and if you go 180 deg it flows much faster it has no reserve  go figure :-\
