Author Topic: Bandido  (Read 2971 times)
Offline Snowy 76
Bandido
« on: May 10, 2009, 12:17:20 am »
Should get long term Bandido project fired up tomorrow, what oils do I need in the gearbox/clutch and what spark plugs should I use. Has twin plug head of Montadero?  It`s been a struggle thats not over yet.!  Thanks Birko.
Couple of CR`s
Offline Moto
Re: Bandido
« Reply #1 on: May 10, 2009, 01:28:42 pm »
Hi,
    What is recommended is 80/90 gear oil in the gearbox and a straight 30wt in the clutch,some people run Castrol MTX in the clutch or ATF/30wt mix.
     B8ES in the rear and B9ES in the front is the standard setup and this also has regards to jetting.
Mark Austin
Re: Bandido
« Reply #2 on: May 10, 2009, 05:40:45 pm »
Hi Mark,
I use Castrol MTX in the gearbox and clutch - or any of the medium weight modern gearbox oils, such as Silkolene or Belray.
Plugs are B8ES with 20 thou gap. What carby are you using? I have specs for a Mikuni on later model 370 that should be pretty close. Let me know if you need any more info.
Mark
Offline Snowy 76
Re: Bandido
« Reply #3 on: May 10, 2009, 09:15:33 pm »
Thanks Fella`s , Think I left Bandido project a little to late, wont make it this weekend. Just a couple of things in bottom end not happy with, will pick your brains on the weekend. Thanks Again.
Couple of CR`s
