Author Topic: v force reed blocks  (Read 5353 times)
Offline caps 999
v force reed blocks
« on: May 07, 2009, 10:57:21 pm »
what are the legalitys of running vfoce reeds in a pre 85 bike
MUGEN power
Offline maicomc490t
Re: v force reed blocks
« Reply #1 on: May 07, 2009, 11:40:59 pm »
I reckon nothing a milling machine won't 'fix', lol  ;)
BULTACO M49 parts wanted
« Reply #2 on: May 08, 2009, 03:00:20 pm »
its a no go Caps. if it wasn't available then its not allowed now basically.
« Reply #3 on: May 08, 2009, 03:21:13 pm »
I would have thought that if it can't be seen from the outside then they should be okay?
"Engines must remain externally unchanged"
"Major components must be period blah blah"
I guess it depends on whether reeds are considered a major component?
Internal I thought was pretty much anything goes with the exception of the gearbox?
Offline maicomc490t
« Reply #4 on: May 08, 2009, 03:49:57 pm »
Eligibility, however you discuss it is always a funny one.
A substantial number of riders use aftermarket (ie current manufacture) shocks which boast multi adjustable everything, front forks fitted with PD valves, fat bars, upgraded (modern) ignitions etc etc.
I would have thought a reed block would be tolerated in much the same way even though V Force are good kit, otherwise a serious review of the abovementioned may be needed ?
Just a thought
Dave Mac  ;)
« Reply #5 on: May 08, 2009, 05:35:39 pm »
i agree, so why is a V-force not allowed then? what if you machine 'V force' writing of the side the reed block so you cant see it. It will just look like a normal yammy reed block then, who will know?
« Reply #6 on: May 08, 2009, 06:19:24 pm »
My reading of the rule is if the engine came OEM with a reed the the CAGE is free. I have made the point before but banning V-Forces is a silly rule as unlike the period GEM blocks that fetch insane money anyone can buy a v-force for reasonable money and get miles better results.
Offline caps 999
« Reply #7 on: May 08, 2009, 06:39:38 pm »
im not looking for power improve if i was doin that id port the crap out of it i just want a 480 that starts
MUGEN power
Offline crabman
« Reply #8 on: May 11, 2009, 02:56:58 pm »
Hi
Can anybody advise me what VFORCE deed black fits a 1978 Honda CR250 Red Rocket. I would appreciate knowing options available. My entire reedblock cage looks a little suspect.
I really appreciate all the help.
Regards
Gavin
Old and slow - and happy
Offline caps 999
« Reply #9 on: May 11, 2009, 03:00:03 pm »
78-86 should be interchangable as the all use the same cage gasket
MUGEN power
Offline roostinu
« Reply #10 on: May 11, 2009, 04:29:35 pm »
there is a few v force blocks floating round on the vmx bikes capps, if u cant run aftermarket reeds, well u cant run aftermarket ohlins shocks.. the shocks will make u alot quicker than the reeds will :-\
Offline k2000x
« Reply #11 on: May 12, 2009, 07:45:26 pm »
i have a gem reed block from74 on my elsinore 250 and it is the same design as the new v force so it shouldnt be a problem new ones are plastic and my gems alloy... big advancements
« Reply #12 on: May 12, 2009, 07:59:48 pm »
G'day Caps, if starting is you problem maybe i can shed some light on how i fire my 85' CR500 up. i'm not a tall bloke but rather stocky (ok then i'm a porker) i had heaps of trouble when i first got it. now i have it nailed. Big bore two strokes need a decent charge in them when cold, not many blokes can kick them over like a 250, so this is what works for me.
on a cold day when it hasn't been started that day or the day before, i pull the plug out and give it a good squirt of "start ya Bastard" or aerostart, put plug back in , choke on, apply easy slow pressure to kickstart (not a kick) until i feel it rock just over TDC, a good handfull of throttle and a big Kick and it fires 1st or second time.
after it has run and warmed up, mine starts  1st or 2nd kick every time on race day if it is not too cold (less than 10 degrees like ravenswood in the middle of winter)
 you may laugh but this work for me.  Good luck.
« Reply #13 on: May 12, 2009, 08:12:26 pm »
The V force reed block is filled in inside the cage to improve the flow compared to a vintage style reed block but i still don't think they should be illegal.
