Author Topic: Can I use bit from this for my engine???  (Read 3063 times)
Offline ss2fly
« on: May 07, 2009, 06:02:19 pm »
Just wondering if parts out of this engine, mainly the crank assembly along with the gearbox and clutch will fit in my TMS125 project Im building?
http://www.trademe.co.nz/Browse/Listing.aspx?id=216399072
I have a NOS set of cases and want to fit these bits into the new stuff......along with the TM stuff on the way ;D
Let me know what will and wont fit.
Andy
WANTED : TM125 EXHAUST, ANY CONDITION!!!
WANTED : YAMAHA YZ250J ANY CONDITION!!!
Re: Can I use bit from this for my engine???
« Reply #1 on: May 07, 2009, 10:22:31 pm »
The head and barrel and throw the rest away. That TF cylinder will be ideal to practice your porting on.
« Reply #2 on: May 07, 2009, 10:31:49 pm »
No fit. You can use TC parts from the same era as yours, these TF agi bike engines are a later design, Of course you could practise your porting skills on the barr.........  :)
« Last Edit: May 07, 2009, 11:20:20 pm by Tim754 »
« Reply #3 on: May 07, 2009, 10:53:30 pm »
tf be 6 stud i think not 4 so top end is useless. bottom  hmm be similar to an er if not the same.
 best let that seized engine go to someone else .
Offline ss2fly
« Reply #4 on: May 08, 2009, 06:28:25 am »
It is apparently an early 4 stud head model, 5 speed. I was / am hoping the guts, ie the crank, gearbox and clutch are compatible for mt old 72 TS125. I'll have a look at it this avo as it is only a few kms away from my place. I dont know if the bits will fit or not......
Anyone had any experience with these????
TM BILL
« Reply #5 on: May 08, 2009, 08:19:51 am »
Mate next to nothing will cross over , spark plug , front sprocket , conrod assembly and piston & rings and maybe a couple of bearings and seals .
Why dont you come to Taupo and i will show you what fits and what dont .
I have about 8 of those motors and 6 of the early TS , TC motors , and no there not for sale at the moment  :)
Make a time and you can see 1st hand for yourself the differences,I will show you TM motors so you can see what you want to do with your TS  cheers Bill.
« Last Edit: May 08, 2009, 08:24:06 am by TM BILL »
DR
« Reply #6 on: May 08, 2009, 01:26:42 pm »
Sounds like a good plan, seeing is much easier than guessing ;) Bill, for record the kickstart idler gear is interchangable too ;D
Offline ss2fly
« Reply #7 on: May 08, 2009, 02:44:07 pm »
PM sent bill
