Author Topic: mx gt80 inlet manifold  (Read 1908 times)
Offline frostype400
« on: May 06, 2009, 09:47:23 pm »
need the inlet manifold off one of these in good condition the type where the oil tube presses on and im after a gasket set aswell thanks Michael. :)
1971 tm400 and PE's
Re: mx gt80 inlet manifold
« Reply #1 on: May 06, 2009, 09:57:51 pm »
have you tryed a yamaha dealer? Be careful getting second hand ones as most will be rock hard.
If you know the part number there is a few sites you can look up the number to see if they are available
Offline frostype400
« Reply #2 on: May 06, 2009, 10:03:57 pm »
i have just emailed a dealer who has helped me before i need lots of little bits preferably nos i nearly have everything thanks Michael. :)
1971 tm400 and PE's
« Reply #4 on: May 06, 2009, 10:54:48 pm »
If you are stuck I should have a most likely 2nd hand freebie for ya. Cheers Tim
Offline frostype400
« Reply #5 on: May 07, 2009, 07:55:32 am »
yep thats what they look like except it should have a nozzle sticking out the top to push the oil line onto i should be able to get  a nos one hopefully if i cant i will let you Tim thanks Michael. :)
1971 tm400 and PE's
