Author Topic: Castrol R 30  (Read 12818 times)
Castrol R 30
« on: May 02, 2009, 01:47:59 pm »
Anyone else use this stuff and get a horrible orange stain on anything the fuel touches ???
Re: Castrol R 30
« Reply #1 on: May 02, 2009, 05:18:20 pm »
The orange will be from water in the fuel, makes to oil go that colour.
DR
Re: Castrol R 30
« Reply #2 on: May 02, 2009, 05:32:36 pm »
I get the really nice purple tinge on anything it's on externally and internally I sometime get a bit of a glaze on the piston but I like the stuff. Actually use both R30 and A747 which is castor based also. A747 is primarily for karts and road racing but it works well in the 125mxer's too as they're ridden pretty much on the stop ;)
Offline jimson
  • Sanctuary point N.S.W
Re: Castrol R 30
« Reply #3 on: May 02, 2009, 06:16:04 pm »
I use the R30 as well its all good even the smell makes me happy  ;D jimson
DR
Re: Castrol R 30
« Reply #4 on: May 02, 2009, 06:30:36 pm »
yes the smell Jimson..pure gold! ;D I use it in my line trimmer, blower and 2 banger mower too and I'm still not sick of it 8)
Re: Castrol R 30
« Reply #5 on: May 02, 2009, 07:10:36 pm »
I use R30 in my modern 4 stroke @ 200:1, spupposedly to help the valves, but really just for the smell. I had a guy convinced I had model car nitro fuel in it at $16.00 per litre once. Smells great combined with avgas.
Re: Castrol R 30
« Reply #6 on: May 03, 2009, 10:07:30 pm »
Castrol Oils are now owned by BP  ::) And yes they have wiped most BP oils off the books in Australia to sell their Castrol products and are "Reviewing" castor based and other low volume racing oils from Castrol now.................................... >:(
Offline oldyzman
  • 250 two stroke!
Re: Castrol R 30
« Reply #7 on: May 03, 2009, 10:12:00 pm »
Hey Guys,
Has anyone had any bad experiences running a full synthetic oil motul 800 at 30:1 in old yz orRM? As if there may be implications i'm all ears to save myself some grief..
Brett
Re: Castrol R 30
« Reply #8 on: May 03, 2009, 11:34:15 pm »
Isnt the "R " now sold in the square tin as "M" ?  as in castor M
Re: Castrol R 30
« Reply #9 on: May 04, 2009, 12:05:30 am »
there is 2 types of castrol R 1 for methenol and 1 for petrol
BONEHEAD
Re: Castrol R 30
« Reply #10 on: May 04, 2009, 06:46:48 am »
i use r30 and the teenage years come flooding back ,its funny how certain aromas stir the emotions, its top shelf and its available at supercheap autos. its like smellig your mums roast dinner on a sunday. ;D.cheers bonehead.
Offline dirttracker
Re: Castrol R 30
« Reply #11 on: May 04, 2009, 07:07:40 am »
castrol m is for methenol r is for petrol.
Re: Castrol R 30
« Reply #12 on: May 04, 2009, 08:14:02 am »
your right
years ago it was only castrol r or shell m.but times have changed now there is castrol m and shell m
still 2 types of castrol r
R30& R40
CHEERS
Offline NR555
Re: Castrol R 30
« Reply #13 on: May 04, 2009, 10:44:14 am »
Thank god for speedway bikes.  Castrol R & methanol produces the best smell on the face of the planet.
Hey Guys,
Brett
Here's a quote from my experience in an older thread that may help you:
We've done a lot of work on oils, and it really varies from bike to bike.  We couldn't stop a CZ bore glazing up on synthetics.  I'd find that by the end of a raceday, I'd be noticeably down on power until we stripped it and honed the bore again.  It was literally a mirror finish glaze.  Motul, Rock Oil, Silkolene, Castrol R2; all the same result.  What's good for modern nicasil, ain't necessarily good for iron sleeves.
We switched to Castrol A747 and it has worked very well.  A lot of you guys would be familiar with this oil, although it's a little harder to find these days.  A747 is a castor/synthetic hybrid.  The fumes have quite obvious Castrol R qualities, and it works best at the richer end of the mixture range.  Castrol recommends where you would run R2 synthetic at 40:1, you'd run 747 at 25:1.
Graham Bell's thinking holds true, especially in two stroke racing like karting.  Air cooled sprint karts rev to silly numbers, and we always ran ours at 20:1 on Penrite mineral oil.
Offline matcho mick
    • Moto Tumbi
Re: Castrol R 30
« Reply #14 on: May 04, 2009, 11:15:10 am »
Brett,been running Motul 800 in my ossa since "rebuild",(hone bore,select best rings, ::),mbrgs,& seals),no probs,but then i'm only doing 3lap races on dirt track,mix is approx 30-40 to 1,also using Motul gear oils in the gearbox/primary as well,all good so far :P
