Author Topic: Clutch Springs for a YZ125X  (Read 2685 times)
Offline crossedup2
  • Never enough shed time.....
« on: April 28, 2009, 09:44:15 pm »
Hi All
Anyone know where I'd find heavier clutch springs for a 125X or alternatively is there a later yamie model that has heavier springs that would fit.
Eg. the trick springs to put in a TTR250 are XS650!
Is there any solutions apart from spacing the springs out with washers (which is already done)?
PB
Re: Clutch Springs for a YZ125X
« Reply #1 on: April 28, 2009, 10:06:56 pm »
Do you need stiffer springs, or just less rooted ones?
How long are your current springs?
Offline DJRacing
  • YZ125X
« Reply #2 on: April 29, 2009, 03:47:59 pm »
Nathan has a point here, measure your springs and check that they are within tolerences and then make up your mind as to if you need heavier clutch springs.
« Reply #3 on: April 29, 2009, 04:27:24 pm »
Barnett and EBC make heavy duty clutch springs for most models. They are around 10-15 % stiffer.
Offline DG 26
  • 250H 125D it490 looking for pre75bike
« Reply #4 on: May 01, 2009, 09:07:18 pm »
crossedup2 neads heavy springs ? alot of weight to drag around  ;D
