Author Topic: CR250 '99 Ohlins Forks  (Read 7955 times)
090
« on: April 28, 2009, 07:44:15 pm »
Wanted for my latest acquisition, my modern ride.
magoo
Re: CR250 '99 Ohlins Forks
« Reply #1 on: April 28, 2009, 09:21:43 pm »
Awesome, the Pre 2000 class. Can't wait.
Hornet
« Reply #2 on: April 28, 2009, 09:28:31 pm »
Are going to have this new class at the nats now ?
Offline E74
« Reply #3 on: April 28, 2009, 09:46:26 pm »
probably can help, leave this one with me, I'll be back to you shortly... ;)
090
« Reply #4 on: April 28, 2009, 10:21:26 pm »
Oh! I shall be a waiting.
Ah, missa magloo! Unfortunately she wont qualify as shes got  a 2000 model heart of the big bore kind!
Offline caps 999
« Reply #5 on: April 28, 2009, 10:30:28 pm »
i have a set to fit an 04 crf250 they may cross over
MUGEN power
090
« Reply #6 on: April 29, 2009, 12:39:00 pm »
Can you measure diameter of forks where top and bottom clamps go? Also distance between bolt holes for brake caliper mount?
Offline SUZUKI311
« Reply #7 on: April 29, 2009, 08:32:59 pm »
caliper bracket mounting hole spacing is different from the 04 model on, easy fix, just replace the mounting bracket with an earlier model one. calipers are same, only bracket different, found out in 2004 when i went to put oversize rotor from my 03 onto my 04, bracket fitted to caliper no worries, but mounting holes were slightly further apart on the fork leg.
090
« Reply #8 on: April 29, 2009, 08:55:31 pm »
Thanks bud. Still anxiously awaiting an answer from either!
« Reply #9 on: April 29, 2009, 09:19:57 pm »
If they are different Brad you can get a complete '04 caliper pretty cheap on ebay. That's what i did with mine. Otherwise you can buy just the bracket like 311 said.
Offline caps 999
« Reply #10 on: April 29, 2009, 11:22:02 pm »
rang cramers today the ohlins gurus in aus told me theres a differnce in the head tubes between those 2 models
MUGEN power
090
« Reply #11 on: April 30, 2009, 05:34:08 am »
How much do you want for them to start with.
A difference does not necessarily mean they wont fit.
I take it when you say "head tubes",you mean a difference in the goose neck?
Offline caps 999
« Reply #12 on: April 30, 2009, 10:37:55 am »
they are asking $3000 im selling them for a mate they were used in the mxnationals in 04 on his  crf and not used since i think youl just need to het the head stock for the tripples as i believe there interchangeble
MUGEN power
Offline NSR
  • Sunshine Coast
« Reply #13 on: April 30, 2009, 09:56:41 pm »
Brad
PM sent
Noel
The Swvm though the tree's! http://youtu.be/4h6BbasT16I
Metalink Conondale vinduro sprint. May 19/20 2018
www.metalink.net.au  Bike trailers & Canopies
090
« Reply #14 on: May 01, 2009, 12:32:01 pm »
Thats more than im willing to part with thanks all the same.
