Author Topic: Montesa front sprocket  (Read 2619 times)
Offline hitatreeonce
  • rather be an old fart than a young dickhead
« on: April 25, 2009, 06:22:19 pm »
Can any one there tell me where to find a montesa '78 360 h6 front sprocket?
Re: Montesa front sprocket
« Reply #1 on: April 25, 2009, 07:10:37 pm »
I have one here not sure if it fits the H6 though. I'll post a pic and you can tell me if it's suitable
« Reply #2 on: April 25, 2009, 09:02:54 pm »
There's two types. One with a tape fit and the other a spline. It was around '78 they changed.
lms6201
« Reply #3 on: April 26, 2009, 07:51:20 am »
when i had the shitbox cota 200 , i machined down the tapered boss off the origional to accept a flat sproket and  welded it onto the boss , took some time on my small lathe
« Reply #4 on: April 26, 2009, 09:37:57 am »
Honda XR fits, but they are flat. You either machine a new spacer or machine the existing one off your old sprocket. There's no need to weld the spacer to the flat sprocket, which makes it easier to replace down the track.
« Reply #5 on: April 26, 2009, 06:01:26 pm »
Hi guys thanks for the help, I did the machining bit a while back with a ducati I owned,if I can buy one outright, alot easier, its an 11 teeth on a spline. How do I get the pic lozza?
« Reply #6 on: April 26, 2009, 06:11:02 pm »
Machining sprocket seems a bit extreme to me. Check with Jared at SW Montesa but I'm pretty sure both are available at very reasonable prices.
lms6201
« Reply #7 on: April 29, 2009, 05:18:15 am »
yes it wasn,t the easiest  mx,or my prefered method , but time was short
