Author Topic: Cota 247 Front wheel spacer  (Read 2061 times)
bitserv
« on: April 23, 2009, 09:00:03 am »
This is for a '73 247. There are 2 spacers on the right side (ie not the brake side) and I have the plane cylindrical one but not the flanged one that sits in the seal in the hub (Part no 21.50.019 - if you have manual). Anyone happen to have one laying around that they want to dispose of for a small gratuity.
PM me with details...
montynut
Re: Cota 247 Front wheel spacer
« Reply #1 on: April 23, 2009, 11:48:12 am »
Hi, If it is the same as my 349's and 242 which I think it is, the spacer you are missing is actually an optional part to replace the original speedo drive when it is removed. Often bikes have the centre of the speedo drive installed which is a cylindrical spacer with a brass collar half way along its length.
The easiest solution is to get one machined up out of stainless steel. It is a pretty straight forward job just dont forget the small ledge on the face that sits against and engages the inner race of the bearing.
You could try South West Montesa or Rocky Mountain Montesa in the US, both are on the WEB.
bitserv
« Reply #2 on: April 23, 2009, 12:56:52 pm »
Thanks for the details. I have the Speedo which I can use as the last resort but it had the original factory spacer and it has disappeared in the worm hole in the garage that occasionally sucks up important parts.....
