Author Topic: conrods  (Read 6771 times)
Offline Fenno
conrods
« on: October 01, 2007, 07:15:12 pm »
does anyone know if the conrod from an 83 cr250 is same an an 84 cr250
the manual states that the bore and stroke is the same as well as piston pin diameter.
a few bike shops have only listing for the 84 cr250re not any older
CR480rd
CR250rd
plus years of collecting 83 Cr junk
Offline Snowy 76
Re: conrods
« Reply #1 on: October 01, 2007, 07:46:25 pm »
I have a PRO-X rod catalogue that says CR250 rods are the same from 78 to 01?,would double check though.
Couple of CR`s
Offline crs-and-rms
  • heaven 23
Re: conrods
« Reply #2 on: October 01, 2007, 09:06:31 pm »
the 81 part number is 13201-430300 the 82 part number is 13201-ka4-700 the part number for the 83 model  is 13200-ka4-741 the part number for the 84 ,85 and 86 is the same it only list,s rod set part number13200-ka4-740  magoo might be able to help with this  . but the 84 model was very diffrent to the 83 model hope this helps
Offline Fenno
Re: conrods
« Reply #3 on: October 01, 2007, 10:03:03 pm »
thanks will get onto Magoo
CR480rd
CR250rd
Re: conrods
« Reply #4 on: October 02, 2007, 06:42:05 am »
Serco in QLD can probably supply a "HotRods" conrod kit for the 84 RE. i have used these for many years in my CR250RG '86 model with no problems at all.
Offline Fenno
Re: conrods
« Reply #5 on: October 16, 2007, 09:23:35 pm »
an 84 rod works fine, same size just a  smaller length main pin (2mil)
CR480rd
CR250rd
Re: conrods
« Reply #6 on: October 16, 2007, 09:32:23 pm »
also if you get stuck try Bikes and Bits importers in WA, sorry dont have their contact details here. they claim to have the worlds largest stock of rod kits and should be able to help you. they have a database of rod dimensions. if they dont have the exact one for your bike they usually can find one from another model that will fit.
have you thought of getting a honda cross reference program from here. ive got the suzuki one and find it very useful
http://www.zedder.com/msg16.htm or http://www.zedder.com/
« Last Edit: October 16, 2007, 09:34:45 pm by LWC3077 »
Re: conrods
« Reply #7 on: October 24, 2007, 08:40:41 am »
great idea however looks like their cross referencing only goes back to '87 and newer CR250s.....d'oh!.....
Re: conrods
« Reply #8 on: October 24, 2007, 07:13:54 pm »
puppie,
Best option is to have the rod removed and get Pro-x to cross reference the dimensions with all rods, 9 times out of 10 a rod from another manufacturer will fit if you can't get a honda one.
Offline Fenno
Re: conrods
« Reply #9 on: October 24, 2007, 07:27:39 pm »
thanks guys but its all done and running like a rocket
like I said the 84 rod works fine
CR480rd
CR250rd
