Author Topic: various TS parts required  (Read 4355 times)
DR
« on: April 17, 2009, 01:47:43 pm »
The items below I'm chasing for projects
TS250 (pre76) seat (looking for a useable seat, small tears or splits okay)
TS90/TS100 seat  (same condition as above)
TM/TS75 seat (same condition as above)
TS250/RL250 pre'75 magneto cover (preferably complete with outa cover)
TS250 early carburetor (bolt on flange type)
TS125 early carburetor (bolt on flange type)
TS250 early airbox
any help with any of these parts greatly appeciated. Cheers
Re: various TS parts required
« Reply #1 on: April 17, 2009, 03:11:06 pm »
is that carby the funny looking thing with the bit on top like a current keien CR carby ?  have one loks to be a bit alloy white on the outside, was on a 76 TS 250
DR
« Reply #2 on: April 17, 2009, 05:12:34 pm »
ummm..I think that one you have freaky is the push/pull job but yeah,
so far as I know it's the same deal except the cable. I have the same style carb ('77 TS400) on my '69 TS250 and it works ok. The TS50 arrived last Sunday as you probably guessed. The frame was cactus underneath (fixable) hence I slipped the motor out and fitted it into the TS75 chassis. Pop off the head, check the bore, no probs, back on with the head, clean the carb, rip out the old airfilter, fresh fuel, connect some wires, 3rd kick and it started and went straight to idle! absolutely minimal engine noise and purrs like a kitty :o 1st kick now no choke and she's away everytime.. a bloody little ripper ;D The TS50 roller I'll repair for a another project. Anyway, consider the carb sold ;) thanks freaky
« Last Edit: April 17, 2009, 05:16:02 pm by Doc »
TM BILL
« Reply #3 on: April 17, 2009, 05:49:23 pm »
PM sent  :)
« Reply #4 on: April 17, 2009, 06:58:17 pm »
sorry bout that Doc, cant say i ever looked at the frame, all i know is the motor ran as the local kids ran it in the back paddock before the throttle cable went, we got it off a dairy farm so that would explain why the bottom has eaten out.
you know if i knew i would have said so.
least its up there and has a new home
DR
« Reply #5 on: April 17, 2009, 08:48:31 pm »
hey Freaky it's no issue bloke. It's obvious no-one would have seen it since the 'moment'. I'm more than happy with the bike but I just thought I best explain why I gutted a TS50 to make something that never existed :) The frame was eaten away by a welder (= the moment) ;) from the looks they've tried to weld on the footpegs, and the bolts and the engine mounts and anything else that was within arcing range but I think they had a zillion amps happening as it's blown bits out everywhere and the wire was all that was holding it all together. Great stuff that fencing wire :D anyway no complaints at all, if you had another I'd buy that too ;D
« Last Edit: April 17, 2009, 08:50:18 pm by Doc »
DR
« Reply #6 on: April 17, 2009, 08:54:28 pm »
I'll post up another picture tomorrow as the bikes in the process of a colour change ::) I did promise I'd build a bike for my ex's little girl and I asked what colour she'd like and she said.........
PURPLE!!!   :o ::) :-X
DR
« Reply #7 on: April 17, 2009, 10:27:32 pm »
sneak peak..err..peek!..still about a week away from completion but I feel the colour suits ;)
gnomester
« Reply #8 on: April 18, 2009, 10:15:23 am »
Liverpool bike wreckers had a TC125 flange carb for sale on Fleebay, rough looking and pricey for appearance.
DR
« Reply #9 on: April 18, 2009, 01:22:39 pm »
thanks Gnomester but yeah, LBW are expensive ;) I can't justify $77 for an old carb that's probably seen many many miles and has the wear and tear to go with it. For $50 more I have seen NOS carbs in Thailand but I was just after a cheapy. About $20 or $30 is my idea of cost for a used TS/TC/RV125 carb ;)
Offline PERM250
« Reply #10 on: April 18, 2009, 09:57:36 pm »
hey chris i have a lot of carbs but i would have to see what one looks like. ed
DR
« Reply #11 on: April 19, 2009, 06:42:55 am »
Cheers Ed, here is a picture of the TS/RL250 carb. The TS125 item is pretty much a scaled down version of the one pictured ;)
Offline PERM250
« Reply #12 on: April 19, 2009, 09:50:05 pm »
hey chris i have just got home i will have a look after work tomorrow for you ed
« Reply #13 on: April 20, 2009, 12:41:32 pm »
the one i got dont look like that it has a square thnbg on the top.
Offline gorby
« Reply #14 on: April 20, 2009, 11:45:38 pm »
I have one but it is missing the slide,needle and screw top :-\
If its any good to you let me know.I have a weathered battery box,speedo bracket,front guard bracket for a TC90 along with that headlight with the flat bottom.
pm me with your shopping list Doc ;)
