Author Topic: Airbox intake boot  (Read 2524 times)
Airbox intake boot
« on: April 15, 2009, 05:20:24 pm »
I'm looking for a rubber airbox to carby boot for a project. It needs to be about 85mm long and 70mm diameter at one end and 55mm at the other end. Anyone got anything close to that?
Offline Husky500evo
Re: Airbox intake boot
« Reply #1 on: April 18, 2009, 04:55:38 pm »
John, did you end up finding a close match for your airbox to carb boot ? I have mentioned in the tech talk section a while back , that the junction rubber on a toilet between the delivery pipe & the bowl might work in some situations like this . I can think of no better source for a part for a Harley, than something off a toilet  ;D. The toilet delivery pipe measures around 52mm( I think it would easily stretch to 55mm) & the porcelain bowl inlet measures around 80mm ( although I think the rubber is stretched about 10mm to go over it). The junction rubber is only about 60mm long though , making it 25mm too short . You could easily extend either end , by using a small piece of stainless exhaust tube as a coupling & 25mm of radiator hose (just means that you would have 4 hose clamps in there instead of 2) .
« Reply #2 on: April 18, 2009, 07:47:17 pm »
Never thought of that one Mark, i don't pay that much attention in the dunny. I was thinking of maybe a fork boot or cv joint rubber boot. Watch out for the harley spraying you with shit at CD6. :D
« Reply #3 on: April 18, 2009, 08:19:00 pm »
called a "flush pipe rubber"
Offline holeshot buddy
  • sunshine coast qld
« Reply #4 on: April 18, 2009, 09:54:58 pm »
this must be for a maico ;D ;D ;D
geoff ballard told me once they used to use cv boots off
subaru i think
but hey if its a maico toilet pipe is fine ;D ;D ;D
follow me to first turn
