Author Topic: TM/TS 125 rear wheel  (Read 1633 times)
gnomester
« on: April 09, 2009, 01:04:05 pm »
Hi ... Does anyone have a complete rear wheel from a Suzuki TM125 or a TS125 up to a 1978 model that they are willing to part with?
DR
Re: TM/TS 125 rear wheel
« Reply #1 on: April 09, 2009, 01:33:44 pm »
gnomester, you can also use TS/TC100, TC100/125, TS185 and TS100/125/185ER rear wheel as apart from the rim size they're all interchangable. Using the later model ER wheel is the go so you have the solid sprocket mount instead of the cushdrive. The transmissions on the little TS/TM are pretty bulletproof so the cushdrive removal causes no problems ;)
« Reply #2 on: April 09, 2009, 02:51:55 pm »
The trailies have steel rims otherwise as Doc says they all the same, The Agi TF range uses same too
gnomester
« Reply #3 on: April 09, 2009, 06:45:21 pm »
Thanks for the info Doc and Tim  :)
I did assume that an alloy rimmed TM wheel would be a rare item to find Tim, so I am happy to accept any steel rimmed wheels to suit. Any wheel that fits is better than none  ;)
Offline brent j
« Reply #4 on: April 09, 2009, 08:22:34 pm »
Gno, once you start looking you'll find thinkgs turn up in multiples!
If you find more than one wheel I'll be interested. From the pics on ebay it looks like that bike has a mudcatcher rim on the front. I'm after a second non mudcatcher rear rim.
I have a photocopied TM125 service manual if you're interested.
Brent
