Author Topic: '81 390 or 420 KTM  (Read 5740 times)
'81 390 or 420 KTM
« on: April 06, 2009, 01:14:02 pm »
Does anyone know the bore size of a 390 ktm? Mine has a 83mm bore which seems big for a 390 and i thought maybe it's a 420? Also the transfer ports don't go close to lining up with the crankcases so maybe it's had another barrel fitted.
oz555ktm
Re: '81 390 or 420 KTM
« Reply #1 on: April 06, 2009, 07:11:29 pm »
Dose youe Engine No# start with?????
560 = to be a 420cc with  85 mm piston
561 = 350cc with a 77.5 mm piston .also engine #  560*****A
562 =390cc with a 82 mm piston also engine # 560*****B
541 = 250cc with a 71 mm piston
« Reply #2 on: April 06, 2009, 07:19:34 pm »
My engine # is 5603413 B. I guess that means it's a 390. Why don't the cylinder ports match the crankcases, it's not even close. Is that normal on these engines?
Offline holeshot buddy
  • sunshine coast qld
« Reply #3 on: April 06, 2009, 08:11:32 pm »
maybe its a maico barrel ;D ;D
follow me to first turn
« Reply #4 on: April 06, 2009, 08:13:44 pm »
Ha ha.. if it was a maico barrel i'd be keepin it just to roost your 465.
« Reply #5 on: April 06, 2009, 08:18:11 pm »
na maicos dont turn remember ::)
 (i can say that i am not in maico forum) ;D ;D
« Reply #6 on: April 06, 2009, 08:20:12 pm »
I'll call the maico police.. :D
oz555ktm
« Reply #7 on: April 07, 2009, 08:33:22 pm »
What you have got is a 420 bottom end with a 390 top end .
dont worry  about the ports you will have all the power you need to
wipp your maico mates
