Suzuki
PE400 coils
Topic: PE400 coils (Read 3325 times)
Grunter215
B-Grade
PE400 coils
April 05, 2009, 04:42:45 pm »
Well .. the plug lead snapped off today so wondering what options. Anyone been there done that?
LWC82PE
Superstar
Re: PE400 coils
April 05, 2009, 04:48:27 pm »
quite possible to repair. you will have to dig away at the plastic to be able to get some bare wire, then solder on a new plug wire. then cover up the repair with an epoxy glue or fibreglass resin or similar. you have got nothing to loose.
Grunter215
B-Grade
Re: PE400 coils
April 05, 2009, 05:13:27 pm »
Are aftermarket ones avialable?? Repair as last option
Re: PE400 coils
April 05, 2009, 05:16:20 pm »
Trim off at plastic, screw in a S/S 25mm long course screw about 12mm trim off head and create a point . Screw on lead and apply a dob of silicon sealant just before if makes contact with plastic and tighten up
Lozza
Re: PE400 coils
April 05, 2009, 05:18:20 pm »
Use $12 pit bike coil fine for HV ignitions
Re: PE400 coils
April 05, 2009, 05:18:26 pm »
Yes after market are available. But are not a bolt up out of the bag item.
Grunter215
B-Grade
Re: PE400 coils
April 05, 2009, 05:43:57 pm »
Thanks ..i think ill give it a go repairing it
Grunter215
B-Grade
Re: PE400 coils
Reply #7 on:
April 15, 2009, 06:55:25 pm »
Hey Oldfart, did your method of repairing the coil..works a treat!! Thanks.
Re: PE400 coils
Reply #8 on:
April 16, 2009, 09:52:37 am »
I see these on ebay all the time and wondered if they'd be ok. They often state that they're for 125cc four stroke pit bikes etc, does mean they'd still work ok on a two stroke motocross bike?
Is there any particular type to look for?
Suzuki
PE400 coils
