Author Topic: RM A/B/C BITS  (Read 1450 times)
Offline SUZUKI311
RM A/B/C BITS
« on: April 04, 2009, 02:29:20 pm »
Have cleaned out the shed some more, surplus bits as follows.
RM/PE 250 Cylinder, .25 over needs rebore-i think its pe as it has slots in the fins for rubber plugs.$30
RM250 A/B Clutch baskets x2 1 excellent, $30, 1 very good ,needs filiing, $20
RM Clutch pressure plate(including lifter shaft) x2, excellent cond, $20 ea.
RM Clutch inner hub x2, excellent cond $10 ea
RM250 RH center case, excellent cond icl kickstart shaft and spring, eng no 26031, $40
RM250 clutch cover, very good cond, $20 (incl clutch  actuator shaft)
shift forks x3, good cond, $5 ea
reed valve, $5
shift drum good cond, $10
kickstarter idler gear, exc cond $10
RM A/B? rear brake backing plate only good cond, $10
Crankshaft-RM250- needs rod and LH side where seal runs needs sleeving, $10.
Or the lot for $150
miscallaneous clutch springs, bearing retainers roller bearings etc free if any one can use them. All parts plus whatever Aust post costs or can take to next Viper/ or VCM meeting ( will be at Ravenswood tomorow if that helps.) call on 0408571900 if i can help.
