Author Topic: 38mm Marzocchi Fork Leg  (Read 2051 times)
montynut
« on: April 03, 2009, 08:59:51 pm »
Looking for a 38mm Marzocchi left fork leg as fitted to early '80s KTM, Montesa and many others. A right hand fork leg would also do the job just in case there is a large surplus supply of only right hand fork legs! :o ::) ;D
« Last Edit: April 03, 2009, 11:17:15 pm by montynut »
Offline ty4
Re: 38mm Marzocchi Fork Leg
« Reply #1 on: April 03, 2009, 09:59:56 pm »
have forks and trees from montesa i think,will check and post pics tomorrow
Offline SUZUKI311
« Reply #2 on: April 04, 2009, 02:14:42 pm »
Do you want lower leg or upper tube? have some zokes in the shed let me know what you need.
montynut
« Reply #3 on: April 04, 2009, 09:03:25 pm »
Hi,
Have attached some photos. Lower fork leg, left hand side required. A right hand side one will be OK.
The previous owner tried to weld mounts to the leg for a disk caliper. I will not bore you with my option of his mental capacity at the time of that decision ??? :o >:(
The forks have 38mm fork tubes. I beleive they where fitted to KTMs as well as Montesa bike along with many other Euros of the period '79-'83.
montynut
« Reply #4 on: April 06, 2009, 06:53:53 pm »
Must be someone with a set of 38mm Marzocchi forks they would like to sell.
