Author Topic: Helmet trickery  (Read 8088 times)
Offline Marc.com
Helmet trickery
« on: April 01, 2009, 07:47:08 pm »
hell knew i had overlooked something in this life, matching helmets...flash as a rat with a gold tooth
Re: Helmet trickery
« Reply #1 on: April 01, 2009, 07:50:11 pm »
10 outa 10 - very 'period' ;) :).
Re: Helmet trickery
« Reply #2 on: April 01, 2009, 08:14:26 pm »
NO WAY   :o
Is that for real  ;D   Gold tooth alright- no shortage of money here folks    ;)    ;D    8)
Very bling with a big fat rat  8)
Alison
Re: Helmet trickery
« Reply #3 on: April 01, 2009, 08:17:41 pm »
fark, that is truly drool-worthy.
Re: Helmet trickery
« Reply #4 on: April 01, 2009, 08:30:20 pm »
is that the same helmet in this listing?
250396891046
i want that face guard!
« Last Edit: April 01, 2009, 08:35:02 pm by LWC3077 »
Offline Marc.com
Re: Helmet trickery
« Reply #5 on: April 01, 2009, 11:48:05 pm »
yes same helmet, my new Japanese VMX connection, though you might not like the cost of the paint work.
Re: Helmet trickery
« Reply #6 on: April 02, 2009, 09:02:12 am »
How much for interest sake Marc? I have done a couple of tanks already in those colors so I suppose the helmet wouldn't be a problem.
Offline Marc.com
Re: Helmet trickery
« Reply #7 on: April 02, 2009, 11:28:07 am »
tank painting about $400 AUD, helmet about $600....problem is exchange rate to yen, I have just sent off a helmet to be painting in NZ along with my RM370 tank.
Re: Helmet trickery
« Reply #8 on: April 02, 2009, 03:38:08 pm »
Helmet painted with stickers $292usd is what he quoted me last week ( you supply the helmet )
contact details        [email protected]
Re: Helmet trickery
« Reply #9 on: April 02, 2009, 05:53:39 pm »
Guys - we have a forum member - Red Alert - who is very well known for his graphics/airbursh work in particular with helmets and painted mine in the old school red white and blue Honda colours.  I don't know what his workload is like but drop him a line for a price.  His work is exceptional and in fact has done some for charity auctions to support the cause.  In Perth also.
Rossco
Re: Helmet trickery
« Reply #10 on: April 08, 2009, 05:42:29 pm »
Whats the go with painting helmets? my new fibreglass shoei says dont modify it or put any chemicals such as paint near it. Can you only paint fibreglass and not polycarbonate helmets? is the only risk the paint fumes getting into the foam? if you fully masked off the liner etc so no fumes can get in it ot reach the foam, should it be all ok then? im half considering it but also dont want to compromise the safety of the helmet. otherwise i will just leave it white and stick on some JT lightning bolts and a few other stickers
Re: Helmet trickery
« Reply #11 on: April 08, 2009, 06:00:48 pm »
Heat is also an issue. Normal 'air dry' should be okay but heat lamps might become an issue.
I'm surprised the Fibreglass helmet said not to spray.
I certain helmets can be sprayed safely otherwise CAMS and MA wouldn't allow custom helmets as they do.
Re: Helmet trickery
« Reply #12 on: April 08, 2009, 06:22:28 pm »
well it more in way just says dont put any chemicals on the helmet like paint, solvents etc, do not drill or modify etc. only clean with mild detergent
heat? is that to stop runs?
so you reckon if you were to mask off the inside and dont use any heat to speed up drying it would be ok?
i would imagine acrylic or 2 back base coat and 2 pack clear over top should be ok? my modern Fly helmet has a thick glossy clear coat which would have to be 2 pack clear i reckon.
a lot of the stuff you read says that the original hemets are 'specially painted, by special helemt painters with special paints etc' but i think its more of just a deterant to stop people doing it them selves?
« Last Edit: April 08, 2009, 06:24:01 pm by LWC3077 »
Re: Helmet trickery
« Reply #13 on: April 08, 2009, 07:26:49 pm »
2 pack on a helmet is fine, i've done many of them. The heat is to cure the paint but it tends to make the fibres swell in fibreglass and could distort a polycarbonate helmet. I can paint a tank like that no problem, i had a bike painting business for years and painted 5 of Barry Sheenes GP bikes for his collection, Mick Doohans camo RZ500 that he restored a couple of years ago, Steve Galls YZ250a, Dave Tanners RN400, RH250, TM400 Cheney and Velocette as well as many others modern and vintage. I work as a mechanic now and just do a little painting on the side if anyone needs any tanks like that done. Cheers
Re: Helmet trickery
« Reply #14 on: April 08, 2009, 07:41:41 pm »
well 2 pack paint is a chemical reaction and it has hardner in it so it will harden/cure by it self. So guess as long as you use no heat it should be fine eh.
« Last Edit: April 08, 2009, 07:43:17 pm by LWC3077 »
